95 SR5 V6 Engine Ticking with RPMs
Old May 16, 2015 | 10:37 AM
garbageman's Avatar
Hey Yota Tech, back with another question. My engine has been making a clicking noise in sync with the rpms (faster, more frequent ticks with higher rpms, less ticks at idle). I thought it would be a valve lifter or clearance issue, but a search of youtube, I can't find much for a tear down and check procedure. Before I opened her up and took a peek on my own, I thought I'd ask here and see what anyone else might suggest, or recomend.
TL;DR, engine ticking in sync with rpms. Suspect valve troubles on driver side. Any guides, or suggestions?
Old May 16, 2015 | 12:22 PM
garbageman's Avatar
Also, I'm pretty sure the previous owner let the oil run low, and blew the head gasket. I find oil, and coolant dried up on the undercarriage when I'm down there. Also, u suspect the brake booster is bad and I've got the tachometer /odo failure. Not sure if anything is related, I doubt it, but just in case.
shooter86314
Jan 7, 2016 07:05 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
beebeeri000
Oct 2, 2015 10:42 PM
sonorn67
Sep 19, 2015 05:39 PM
