95 cummins build
Old Jun 19, 2013 | 01:50 PM
  #121
maachine's Avatar
hahaha, ya man. i grew up in a family of 6 kids. i'm going to get snipped here in the next few years.....one is enough
Old Jun 19, 2013 | 02:06 PM
  #122
highntight's Avatar
ya thats about all i need...
Old Jun 23, 2013 | 02:14 PM
  #123
IhateUSERnames's Avatar
looks good
Old Jun 24, 2013 | 08:08 AM
  #124
highntight's Avatar
thank you..... i havent drove the old girl for about three weeks now. shes feelin neglected. need to get out and take more pictures.
Old Jul 24, 2013 | 08:56 PM
  #125
Dreidel's Avatar
so i just picked up a cummins for my 95 and people have been saying that you need a body lift but nobody has said what hits if you dont use one. is it the tranny or the crossover tube? just wonderin
and did you do any oil pan mods or is it stock
Old Jul 25, 2013 | 05:55 AM
  #126
highntight's Avatar
your going to need at least a 6 inch lift. i went 5 and had an existing body lift on the truck that i left there. two inch if i remember right. and i can still get my steering arm into my pan.... no i did no mods to this pan. i ran a bump stop on one side is all needed and still gives a ton of flex. but as much as i do not like body lifts i would do one as well. and get your 4bt as close to the hood as posible...... does yours have the water over air or just air intercooler?
Old Jul 25, 2013 | 05:59 AM
  #127
highntight's Avatar
also.... thats with a sas. not sure about independent....
Old Jul 25, 2013 | 08:22 AM
  #128
Dreidel's Avatar
Mine is a 88 so no intercooler I have one my step dad gave me but idk where I'm going to stuff it
I have a 95 2wd reg cab that's been sased but its stock height for now I want to keep it lower so I thing I'm going to do major pan surgury and a cowl hood maybe I want it to sit some what low with the 36s that are going on it but still have pretty good flex plus I'm doing a heavy duty ruf to pull the axle forward some more too
Old Jul 25, 2013 | 12:06 PM
  #129
highntight's Avatar
oh hell, sounds like you got it figured out. not havin air over water will save you a few inches as well. i think what your talkin about is for sure doable. should be sick.
Old Jul 25, 2013 | 04:20 PM
  #130
Dreidel's Avatar
Ok cool nice to get a opinion from somebody wgo has dine the swap the others I've seen use the factory v6 rad do you think the 4 can handle it heard the 4bt don't make a lot of heat
Old Jul 25, 2013 | 06:41 PM
  #131
highntight's Avatar
im running the stock 6cyl rad its cools fine wheeling the fans keep it at 190 and they dont run constantly ether.... highway it runs great...
Old Jul 26, 2013 | 01:19 AM
  #132
Dreidel's Avatar
I suppose I will try my 4cyl rad first and see how it does if not parts yard isn't to far away
Old Jul 26, 2013 | 01:23 AM
  #133
Dreidel's Avatar
Oh and were the v6 motor mounts close to where the 4bt mounts are after doing some measuring on mine the 4bt mounts are 1in in front of the center of my 22re frame mounts (roughly with 1in between head and firewall all measurements are roughly still since I'm still driving my truck)
Old Jul 26, 2013 | 09:53 AM
  #134
highntight's Avatar
i d k i think they were close. i just cut everything out and started new. got the motor set where i wanted. and made everything out beer boxes and layed everything out on plate and cut it out. the 4bt has tons of room in fact more then the original 6cyl. you could run a stock fan with the 4bt. infact thats what i recomend doing. stay away from electric. thats my only bitch about mine. some day i will change mine maybe leave the outside fan for good measure. they also sell some fancy liquid motor mounts for the 4bts that take alot of shake out. also find a harmonic balencer off a 6bt it will take alot of vibration out of the motor. probably find one for nothing if you look hard enough.
Old Jul 26, 2013 | 10:03 AM
  #135
Dreidel's Avatar
Arevyou talking about the fan that doesn't have a clutch on it?
Old Jul 26, 2013 | 11:15 AM
  #136
highntight's Avatar
no the stock clutch fan will fit with about and inch to spare. i never had one so didnt use one i put electric on it. and i wish i would have just put one on. and left the outside electric on there just for back up. i have a pusher and a puller fan on there now both electric.
Old Jul 26, 2013 | 11:18 AM
  #137
Dreidel's Avatar
Ahh I see
Old Jul 30, 2013 | 11:02 AM
  #138
Whitekid434's Avatar
I believe its been said before, but yota of my dreams! If I ever get rich, or run into a good amount of money to blow, my yota will definitely be a Cummins. I can't begin to tell you how awesome that thing is. Excellent job
Old Jul 30, 2013 | 04:05 PM
  #139
highntight's Avatar
Thanks man. I'm gonna do a black hood this weekend. Gonna try a hood scope. Don't know how it will look so I don't want to ruin my hood..... So I bought another to see how it goes.
Old Aug 6, 2013 | 07:26 AM
  #140
highntight's Avatar
took some poser picks with the air lift under the front and rear makes it huge just getting the tires barley off the ground. had to rotate tires and this is the easiest way.....
