95 cummins build
i always post mine to www.photobucket.com or www.youtube.com
i have a small 4 banger yota diesel ... i wish i had a real diesel in my truck... your truck is one of the nicest americian toyotas i have seen done.. are you running any special transfer case or doubler??? and is the tranny a 2wd or 4wd??
and you do cruise this around town right? cause its gotta be the baddest toy in town
Nice build!
Do you have any pictures underneath the rear bumper?
I just want to see how you mounted the rear bumper to the frame as I'm in the middle of cutting up my rear bumper and am curious to see how you've done it.
#25
im not into the swap much really... im running an sm420 trans... first gear ratio is like 6.somethin to 1 with a chev 208 t-case with the 4.11 gears its a crawler or sure, its a pig... havent found anything it wont crawl. i did the milage on it and got 23.4, so really good even for the 37's. i just molded the chevy floor pan into the old floor, so it worked out sick. i through up some pick of inside the cab. i ran all mechanical gauges and i think i threw up a pick of the dash bezzel i built for it...
#33
Well the battery and the air cleaner would have been best if I would have switched them around. But I was lazy and just built the intake across the front to the original location. But it turned ut sweet. I like when it ended up. I just used a cupple. Braces off the block bolts. I hope I'm never in water that deep. Pun intended...
#37
oh im excited about it... sold the red one in the pick today. im going all the way, full frame off. ground up build 4 wheel drive, 4in superduty lift, same red as my dodge was, all blacked out on 37's and those 20in wheels that were on that truck. and a built cummins 5.9L 12 valve. baddest pulling truck ever. nv4500 i already have the storm block 12v nv4500 and a np241 t case. a 78 hp kp 60 front axle and 14 bolt... i have all the high dollar gummy bears. so hopefully it will go together quick.
the only truck i have now is the yota. but i talk alot of crap to my buddys and tell them im putting a fith wheel hitch in the back so i can pull them home, with the cummins when they brake down
awsome i'm in love i'm very impressed with the whole project. how well would it do if you re geared it for the street? tire burner?
