95 4Runner won't start
Okay, hopefully I include all the information I need to here so that hopefully you guys can help me out. On Thursday I got my heads back from the machine shop and started the reinstall of everything on Friday evening.
Today I finished getting the majority of everything back together with the exception of the power steering pump, distributor and timing belt and covers. I was wanting to attempt to turn the truck over to break loose the bolt on the crankshaft - that was a no go since I didn't get anything. Well not anything, but the truck wouldn't turn over at all.
At the moment, I have working headlights and interior lights, but nothing else works. No power door locks, no windows, nothing.....
Could it be a ground strap issue? Possible connector not connected correctly? Forgot to mention, this is for the 3.0 V6.
TIA!
Andy
TIA!
Andy
Looking back at the install guide from the Toyota guide, I'm curious to know if I got the ground straps connected correctly. The left side ground strap goes to the alternator right? I don't recall disconnected a ground strap on the right, and all other connectors are connected (or so I can see). Currently the heads are reassembled, fuel rails and injectors as well as intake manifold and chamber. The only things not currently connected are the radiator, power steering pump, and the timing belt and such. I was hoping to just turn the engine over to break loose the nuts on the crankcase pulley.
Ideas?
Have you tested the battery? Could be dead enough to not power everything. Defiantly check grounds, that could be an issue, but I don't see why that would effect half of your stuff not working.
I would also check that cables look good (not frayed or broken) it could be that when you we're reinstalling/removing the heads, you accidentally caught a line and either frayed it or cut it or something, that would be the next thing I would look for.
Good luck!
Good luck!
Good luck!
Good luck!
As for the ground strap coming off the left fender apron, does this go to the alternator? that's were I grounded that one, and I don't believe I took a ground off the right fender apron. I can say for certain that I know I took extreme care when removing everything and all wires are intact and not frayed.
~Andy
It shouldn't be too hard to break that bolt loose, I was able to. I think I put it in1st and had it backed up against a wall and then used a cheater bar and hammer. And I think that the ground goes to the #4 cyl.
Is it possible for someone to post a pic for me of this ground going to the #4 cyl?
Andy
Thanks for all the help and suggestions - ended up finding out that the truck didn't have power because of an Alternator 80A fuse. I guess it was slowly dying or had intermittent connectivity. I replaced the fuse and all seems good now. Finishing up the exhaust tonight and then should be able to take her for a quick drive. Thanks again!
Andy
Andy
aciorba23
Jun 29, 2015 04:18 PM
