95 22re warm start idle drop then runs fine
Old May 20, 2015 | 10:36 PM
WARxMACHINE's Avatar
Hello all i have a 95 22re when i start it cold it idles up and runs fine drive it for what ever amount of time and then shut it off if i start it back up within say 2-3hrs the idle is very low 290-350 and the motor bucks and misses if i let it idle like that for a while the idle will return to normal i have replaced the colant temperature switch but im leaning twords IACV/AAV truck runs fine except after warm start i dont know where to begin
Old May 21, 2015 | 07:56 AM
grumpin's Avatar
Some of us have had this problem. Here is a post to read through. https://www.yotatech.com/forums/f116...t-issue-288051
Old May 21, 2015 | 09:22 AM
The truck in this case has no fpu on top of the thermostat housing
Old May 21, 2015 | 10:33 AM
grumpin's Avatar
Ah, should have payed closer attention to your year. I believe they stopped using those later.
Old May 21, 2015 | 11:52 AM
Janos01's Avatar
The issue you described could also be the result of a bad fuel injector. My 90 4runner had the same symptoms, started fine when cold and if I parked and turned off/on again, i had the same rough Idle. A bad vacuum leak could cause this as well. I would recommend purchasing a fuel treatment to clean your injectors such as Seafoam or the Chevron w/Techron. Check the your vacuum lines & intake as well.
Old May 21, 2015 | 07:17 PM
it starts up fine when warm no excessive cranking involved it wil start ok then the idle drops after 3 seconds plugs are dry and i have sprayed carb cleaner and have misted water on the lines as well no vac leaks anywhere
Old May 22, 2015 | 08:33 AM
Janos01's Avatar
Mmm, might be the ignition coil, distribiter or a cable that runs to it. Try putting one of those injector additives and see what happens.
Yont283
Sep 23, 2022 08:06 PM
zd92655
Mar 6, 2022 12:58 PM
puffin04
Jul 10, 2015 09:17 PM
slider417
Jun 22, 2015 10:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
