94 toyota pu 22Re
Old Oct 10, 2007 | 04:53 PM
swcust's Avatar
94 toyota pu 22Re
Truck has looses all porwer at load 3000 rpm we have put in new o2 sensor fuel pump, fuel filter 1 year ago when engine rebuilt. no codes are showing according to the mechanic.
Old Oct 10, 2007 | 04:59 PM
Albert.G's Avatar
not throwing any codes/
BeaterToyota's Avatar
Welcome.
I have a '94 with 22RE also and it's been running pretty poorly lately.
There were a lot of things overdue, and I didn't expect them to fix things but I changed them anyway: new plugs, wires, distributor cap, and rotor. I also replaced the fuel filer and air filter, and adjusted the timing and idle speed. It's a little bit better, but still not right on.
I'm gonna keep an eye on this post to see what suggestions others have for you. Maybe some will help me out, too...
Old Oct 10, 2007 | 05:11 PM
swcust's Avatar
no codes took in and had some one look at it
Old Oct 20, 2007 | 08:09 PM
84sr5yoty's Avatar
If the problem arises specifically at 3000 RPM's, then the air flow meter would be the first component to test. I don't have the specs on me, but there are voltage and ohm specs that are in the factory service manual to test for proper operation.
Other possibilities that would not generate a code include a worn fuel pump, bad fuel pressure regulator, and clogged catalytic converter. A very rare possibility would be a bad fuel pulsation damper, but as I said, it?s VERY rare.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
