'94 Toyota Pickup R150F Leaking Transmission Oil from Breather Port
Old Mar 12, 2023 | 11:12 PM
DarethZ's Avatar
Post '94 Toyota Pickup R150F Leaking Transmission Oil from Breather Port
1994 Toyota Pickup 3.0 V6 4x4 5 speed Manual Transmission R150F
The Main Point:
The transmission is blowing oil out the top through the breather port on the driver side of the stick and I'm not sure why. See pictures here: https://imgur.com/a/v8Is6X2
Here's a post I found that had pictures of the same transmission removed from the truck: https://www.toyota-4runner.org/2104216-post14.html
Troubleshooting steps taken:
I noticed the leak, put it up on a lift and tracked it down to be just from the one breather port. The retired mechanic DIY shop owner suggested putting a hose on it and extending it up the backside of the engine block. The tan tubing is what I used to do something similar in the troubleshooting process, but driving 5 miles the 3 ft tube fills and starts overflowing.
I went to the nearest auto parts store and asked about who works on import cars or transmissions specifically. The advice I got was to take some silicon and just plug it because there is (or was probably) a plate that has disintegrated over time that prevented the oil being flung up through centrifugal force out the port. I figured I'd pull my shifter off and make sure that the multiple breather ports were connected somehow just in case. From what I can tell the ports are for separate areas so I'm not sold on this idea.
For a better idea on what transmission I'm talking about here's a link to a video where a youtuber swapped in the transmission I have into an older rig:
at the 1:30 mark.
No the fluid level is not overfilled; filled fill to spill from the fill port on the side. I originally did a top off when I was troubleshooting a different problem post head gasket change and discovered the transmission was low on oil, but now I've done a full drain and refill with Amsoil 75w-90 gl-4. Link to manufacturer's website: (https://www.amsoil.com/p/manual-tran...AaAs_wEALw_wcB)
The old oil was badly in need of a change and now that the oil was changed it now comes out faster. The old oil was a blackish brown with what looks like a decent amount of microscopic metal shavings for a truck with 250k miles. (pictures in the imgur album above) Tends to happen to a person new to a manual transmission, but no big chunks. Go-figure new oil has lesser viscosity than the old congealed etc etc.
I drove it very little troubleshooting problems after the head gasket change and I added 200 mL to bring it back up to full when it was about -10 degrees F in my front yard.
After those problems were fixed I noticed a burnt oil smell. I had maybe driven it about 50 miles at most since I topped it off and ended up putting an entire quart in to bring it back to the fill port level in the ~65 degreee F shop temps.
No the transfer case is not bleeding through a seal and mixing in the transmission. The transfer case is red atf and the 75w-90 is clear. Only spews clear and the transfer case oil level never changes.
Car History:
I bought this truck in March of 2021 as a temporary beater that I decided to keep as a daily driver since 19 mpg better than 12 with my F350. I'm at least the 3rd owner.
I took it to the local shop to have them do a pre-purchase inspection to see if they saw anything that I didn't see. At the time the transmission level was proper at this point at least according to their checklist. The truck has/has had leaks in most of the other fluids that I'm constantly keeping an eye on, but the transmission had no sign of a leak so I hadn't pulled the fill port screw off to check it again until 1.5 years after I had it.
The truck has zero issues shifting and I only noticed the low oil troubleshooting new sounds after I got it back from the shop after a head gasket change.
Thoughts? (besides the fact I should have figured out how to check the transmission level sooner when I couldn't find a dipstick having come from only automatics previously. >.> we don't speak of that....)
EDIT: I verified that the 3 breather ports are not connected and that plugging 1 is a bad idea before I tried that. Probably going to take it to the nearest shop to rip it into pieces because they can't screw it up worse than it is now.
Last edited by DarethZ; Mar 25, 2023 at 08:38 PM. Reason: new information added to end.
Tubbyfatty
Sep 20, 2009 08:06 PM
dj-86yota
Nov 24, 2008 09:21 AM
pro8cess
Feb 20, 2008 12:47 PM
Andyman
12
May 19, 2004 09:58 PM
