94 4x4 pick up condensate problem with clear drain
Old Jun 23, 2015 | 02:33 PM
racefan8's Avatar
can anyone help me. 94 pick up a/c condensate water getting on passenger side floor drain hose clear. Although still seams like housing is full and does not seen to be emptying completely. any help would be greatly appreciated
Old Jun 23, 2015 | 02:37 PM
millball's Avatar
Can you get an old piece of speedometer cable core up the drain and try to rod it out??
Old Jun 23, 2015 | 05:24 PM
racefan8's Avatar
So you think the little neck from the fire wall into the plastic housing that little area is blocked also because the rubber piece leaving out of the fire wall and the aluminum piece is wide open
Old Jun 23, 2015 | 05:56 PM
Terrys87's Avatar
Even though this thread is for the 84-88, https://www.yotatech.com/forums/f116...trucks-286766/ virtually everything is the same for the 89-95. The dash just disassembles from the passenger side to the drivers side. Might actually be easier on the 89-95 trucks. Most likely this is your problem. Also the cowl vents let a lot of junk down to the air system.
Old Jun 23, 2015 | 06:25 PM
millball's Avatar
Common sense says that it has to be plugged up somewhere.
Old Jun 23, 2015 | 11:13 PM
wyoming9's Avatar
Red face
Mine has been draining on the floor for quite some time. I just keep forgetting to fix when I have time.
it is only water .
My big feet drag more mud and water in every day it rains
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
