94 4runner with broken elocker ?
Old Mar 18, 2009 | 07:11 AM
Nashman00's Avatar
well i find this kidna odd that i broke mine and was woundeing if any body has broken the side gear
for some reson i think the axles are to short cause them to not fully go into the diff that or side load bad or just plain norm
you can see by how much about 3 mill going by the axle
Old Mar 18, 2009 | 07:38 AM
Hypoid's Avatar
Good question.
I know Bobby Long sells long inner shafts for electric lockers. Of course this is for front applications but since the diffs fit front or rear (solid axle) I wouldn't think it'd be different.
Anyone compare an elocker to a regular diff for spline engagement?
Old Mar 18, 2009 | 08:29 AM
Nashman00's Avatar
oh i broke it going over this little hil in 2wd not locked at all
i gonna be getting my new axles today and gonna do proper measher ment befor i do any thing
so am the only one this has happend too ?
Old Mar 18, 2009 | 09:00 AM
ZUK's Avatar
ZUK
That spline engagement seems normal to me. I seem to remember that between 1.125 and 1.50 engagement was what I measured in the past.
Regarding the broken sidegear. I have seen this twice and documented it once. I'm wondering if a bent axle or axle housing has something to do with it. I also noted that some of the replacement sidegears have a thicker splined sleeve.
see this
http://gearinstalls.com/elockerbroken.htm
Old Mar 18, 2009 | 09:04 AM
DeathCougar's Avatar
Where did you get the diff from? More importantly, how long have you had the diff and how much abuse has it suffered in the past?
Old Mar 18, 2009 | 09:16 AM
Nashman00's Avatar
all right thsi is what i have gather form toyota during this hole bs
toyota after 2001 they change the rear diff as in part number changed you only chould buy it as a hole 95 and up use allt he same part number's and you chould buy the side gear by it self now is it diff not sure
here is the part number for the gear that breaks 41331-3401
this is for 96 to 01 now is it the saem as the old one not sure
i bet if the axles was just longer there whould not be an issue since the other side will never break cause it just thick gear it will strip be for breaking
so going to put some gears int here and do a test fit and see what is up i may ahve ot go custom axle that just longer
Old Mar 18, 2009 | 09:17 AM
ZUK's Avatar
ZUK
see this
I have an update on that repair I did back in Nov....he went out on 1 trailride(in March) and broke the same side again. I'm thinking that it's not the lockers fault ....that something else is going on....maybe something bent.
Old Mar 18, 2009 | 09:20 AM
ZUK's Avatar
ZUK
you could be onto something there.
Old Mar 18, 2009 | 09:33 AM
ZUK's Avatar
ZUK
Nash--I wanted to record that part number...but it seems to be missing 1 digit at the end? 41331-3401
edit....found it
4133134012 $98.86 $0.00 $71.32
Universals & rear axle - Rear axle - Differential - Side gear
Side gear, t100 1993 - 1994
Old Mar 18, 2009 | 09:49 AM
Nashman00's Avatar
that is it
i was on the pone with jay mark's toyota for some time tring to figure out this issue with the truck guy there best place for custmore support any were and cheep price
some thing change
Old Mar 18, 2009 | 09:55 AM
Nashman00's Avatar
well i got my axles today i gonan find out what the back spaceing is and how much of the ticker part os the gear is holding the shaft
Old Mar 18, 2009 | 01:50 PM
89-4Runner's Avatar
If the locker motor is not properly timed the splines will engage a 'little' bit, making you think you're locked but it's not fully. The longer splined axle shafts spoken about earlier for the elockers are for the 8.4" landcruiser lockers, not the 8", longer splines not necessary
look at the last page of this PDF:
http://www.oceanstatecrawlers.com/OS...reassembly.pdf
Old Mar 18, 2009 | 04:00 PM
Nashman00's Avatar
mine broke when i was in 2wheel and no lock
Old Mar 18, 2009 | 07:18 PM
Nashman00's Avatar
every thing cheaked out fine my axle was bent
so now i feel ok now
Old Apr 2, 2009 | 03:41 PM
RHayes's Avatar
Mine just did the same thing and my 4runner is up on blocks with the 3rd pulled. I will check to see if my axle is bent.
Old Apr 3, 2009 | 01:19 PM
ZUK's Avatar
ZUK
...so you feel ok now that you know the axle was bent?
How bent was it?
rushw
Jul 18, 2015 01:46 PM
88yodabasket
Jul 13, 2015 01:32 PM
jon.r
Jul 11, 2015 03:34 PM
Snort
Jul 9, 2015 03:58 PM
akaphilly
Jul 9, 2015 02:34 PM
