94 4Runner 3VZE Chassis Engine Perches
Old Apr 2, 2024 | 06:26 AM
kingroon's Avatar
Hi All,
I had my '94 3VZE 4Runner at a Garage most of last year undergoing a full Body Off Restoration, during this time I replaced my rusty Chassis with a sourced rust free one.. The Garage doing the work however binned my old Chassis before they removed the 3VZE Engine Perches from the Ladder, and instead fabricated a set.
Trouble is, they didn't do a 100% Job, and now the Engine sits a little bit too low i.e. dipping a touch at the front.. This is causing problems with Exhaust Routing [I installed Headers], and the Cooling Fan..
I cannot get a 3VZE Chassis over here in the UK, so wondering if there are a) 3VZE Perches available somewhere or b) if someone has a rusty 4Runner Chassis they could sell me the Engine Perch[es] section from..??
Any help gratefully received..
Old Apr 2, 2024 | 06:51 AM
rattlewagon's Avatar
How low is too low?
Since you have to cut the old ones off anyway, would it be possible to make new taller ones? I can measure mine later if you need a length.
Could you ad or make a spacer like this to bring it up? https://www.4crawler.com/4x4/CheapTr...oogle_vignette
Heres a shot of my stock height mounts.
Old Apr 2, 2024 | 07:14 AM
kingroon's Avatar
Hi @rattlewagon , and thank you for your reply..!
I guess the problem is that I don't really know how too low the Perches are.. Since most of the 4Runner / HiLux Surf here in the UK are Diesel [1KZT or 2LT], I don't know [since my 3VZE Chassis was disposed of] the difference in Perch height between the Diesel versions and my v6 version.. All I do know, from looking at the first photo of my original post, is that they are different.
That solution from 4Crawler might just be the ticket.. I bought my Body Mount Kit from Roger, so happy to give him repeat custom..
If it is possible, could you measure the distance of the Blue Arrow, below..?? I can then do the same with my fabricated Perches and check the difference..
Old Apr 2, 2024 | 05:22 PM
Looks like 1.75 on the bottom parts. 2" to the edge of the bracket
Opps duplicate post.
Old Apr 5, 2024 | 12:16 AM
kingroon's Avatar
Fantastic, thank you .. I'll get mine measured and report back..
Old Apr 26, 2024 | 07:19 AM
kingroon's Avatar
Well, it looks like the Perches on my 4Runner are about an Inch in total, so there is definitely the need to have them extended..
I couldn't get a Tape Measure in there to measure accurately..
kingroon
Diesel Swaps
Jan 7, 2026 03:58 AM
kevino
Aug 19, 2011 09:56 AM
funrunner91
Jun 16, 2007 12:28 AM
Cebby
Dec 28, 2006 07:06 AM
