94 3vze what is horrible engine noise?
Old Mar 26, 2008 | 09:35 AM
bill buttermore's Avatar
Had a chance to do a little more work on the 4runner. My replacement parts arrived today, so I will be cleaning up and re-assembling things now. I was pleased that damage from the broken crank appears to be limited to the main bearing inserts for the #4 main bearing and some piston skirt scuffing. Here are some pix:
Crankshaft end showing broken surface:
Journals look amazingly good on the broken end:
Crank journals look good. #4 main bearing shows scuffing:
Main bearing bottoms look okay except for #4 which shows scuffing from the broken crank end wiggling around.
Thrust bearings look pretty good:
#6 rod bearing showing some damage:
#6 piston showing some scuffing:
Piston tops are dirty, but show no evidence of striking valves:
Cylinder heads show no damage - valve margins look good:
Old Mar 26, 2008 | 11:54 AM
MonsterMaxx's Avatar
Are you really FIXING that POS? You are kidding right?
Old Mar 26, 2008 | 02:28 PM
Well, it has already gone 172,000 miles. It appears to be basically sound; block and heads in good shape, decent compression. It will cost about $500 - $600 to repair with a reman crank, new rod and main bearings, new head gaskets, vc gaskets, new crank seals and cam seals. Ought to go for a good long time when I get r' done. Seems like a reasonable, cost effective approach.
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
Gamble_STi
Jul 7, 2015 07:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
