93 wont start just turns over and over (3VZE)
Old Apr 23, 2009 | 01:33 PM
wyorunner's Avatar
Unhappy 93 wont start just turns over and over (3VZE)
Long story short, broke a distributor cap bolt had to pull the distributor to drill and tap the hole. Put the distributor back in it was missing due to being out of timing, fixed that enough to where it should start. Now there is a clunk in the airbox when trying to start. It will just turn over and over and over, and then every now and then ill feel the clunk in the airbox, which that might not have anything to do with it. I dont think its a fuel issue because i can smell the fuel which makes me think it might be flooded but on a 93??? I need some expertise. Any help would be appreciated.
Thanks
Wyo
Old Apr 23, 2009 | 04:55 PM
Bobzombie's Avatar
Timing is 180deg off. Call me if any other issues.
Old Apr 23, 2009 | 06:34 PM
PlugItIn's Avatar
x2...
Old Apr 23, 2009 | 07:32 PM
24Runna's Avatar
Originally Posted by PlugItIn
x2...
x5
Same thing happened to me, except it sounded like a gunshot.
No. 1 Cylinder should be at compression, the 0 mark on the crankshaft pulley. Then the distributor should be pointing a bit to the left, on the No. 1 spot.
Flip the engine if it still does it. When you took it out you probably didn't have the engine at 0.
Here's the PDF.... http://www.filefactory.com/file/agdd...istributor_pdf
zd92655
Mar 6, 2022 12:58 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
88Toy
Jul 4, 2015 02:11 PM
rbravo1
Jun 29, 2015 01:34 PM
