93 5speed 4wd ecu trouble!!
Old Jul 28, 2022 | 01:56 AM
evantgilbert's Avatar
So I bought a 93 22re 4wd 5 speed… with a supposedly bad ecu? My question is what years will make it run? Not worried about a engine light… just wanting to get it running! The vin give me the 89661-35830 which says for a 4 runner? The numbers are gone in the actually ecu so I can’t confirm that? The truck will run about 2 minutes then die and the light comes on… I’ve checked for codes and none show… the guy I got it from had wheeler it the day before ecu gave trouble I assume he got it wet?
Old Jul 28, 2022 | 04:58 AM
scope103's Avatar
Well ... a bad ECM could always cause all sorts of problems. But replacing one is a big step, and in general should be the last step of your diagnosis.
"Runs for a few seconds then dies" is the classic sign of a VAF-COR problem. Here's how you can find/eliminate that: https://www.yotatech.com/forums/f116...-quits-312747/
Old Jul 28, 2022 | 05:07 AM
Thanks I’ll check that…. I have the ecm out and there is def a burnt spot so I’m just assuming that’s the issue?
Old Jul 28, 2022 | 03:45 PM
Bump ttt for some more guidance
matt0922
Dec 10, 2012 06:05 AM
aceofsnett
Jan 10, 2012 08:56 AM
odonekanobe
Jul 18, 2007 07:35 PM
nrgetic99
Nov 10, 2005 10:58 AM
