93 4runner rear window removal problem
Old Oct 2, 2009 | 03:18 PM
cmuller0420's Avatar
hey....soing... my rear window doesnt work (seems like a common problem)...anyways here is what is happening
The motor works...it makes noise at least when i pushed the button for up an down
I removed all the paneling to expose the motor assembly. I think that the arms have seized(rusted in place) in the up position. Now the other issue is that the window is up....so I am stuck on how to remove the assembly and/or get the window down.
Also wondering that if the motor is trying to move seized gears if it would develope a problem with wrecking its "output".
Thanks for any advice.
Old Oct 2, 2009 | 03:37 PM
Marc's Avatar
If you remove the motor you should be able to move the window in and out.
Old Oct 2, 2009 | 04:58 PM
slacker's Avatar
the motors are pretty strong .. and usually wont quit , It's the gears that fail . and on the window regulator , the gears/fingers will fail + the rollers .
you can usually rebuild it all , with a few replacement parts ... If your willing .
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
