93 22re Shutdown while driving
Old Dec 30, 2019 | 01:39 AM
Damasio Taylor's Avatar
Hi guys! Driving home from work Saturday night cruising at 60 started losing power. Downshifted to 4th tried kickstart. Nothing. Pull over tried multiple times. Nothing! Pull it to my house. Put a jumper in the port. I hear my pump. Tried cranking and have spark. Sat a few more minutes. It cranked like normal. Ran bout 45sec got really rough and cut off. Just turns over. Came back next day pull code13. Tried cranking it did same thing ran 45sec shutoff. I got 12hr shift and dont wanna pay Uber! Help please.
Old Dec 30, 2019 | 01:49 AM
Co_94_PU's Avatar
Codes 12 & 13 are no RPM signal to the ECU from the distributor..
Your gonna be paying for ubers..
Could be the NE signal coil in the distributor, or a wiring issue in-between the two.
Old Dec 30, 2019 | 05:23 AM
What is the NE signal?
Old Dec 30, 2019 | 10:57 AM
Co_94_PU's Avatar
It's an engine position sensor, part of the ignition timing system. Located inside the distributor.
Maybe a red herring, but you do have a trouble code for it.
Another highly probable cause is the circuit opening relay which turns the fuel pump on/off.
Old Dec 30, 2019 | 02:52 PM
RASALIBRE's Avatar
Did it happen to be raining or water on the streets from melted snow? I’ve had this happen with wet weather, ended up being moisture in the distributor cap. New o-ring solved it...
If it’s not that, CO nailed it.
Check the air gap at the pick up in the distributor, bad pick up coil in the distributor, bad/melted wiring between the distributor and ignitor, bad melted wiring between igniter and ecu, bad igniter (apparently not all that common), or bad distributor (they can wear out, but not too common).
Old Dec 31, 2019 | 09:34 AM
Yes it was a Lil damp that night! It had rained earlier that day and a little that evening street were a still wet when I got off work. I haven't tried cranking her in 2 days. I'm go an try in a few. Thanks guys for you knowledge!
Old Jan 3, 2020 | 07:56 PM
jbtvt's Avatar
If the jumper when you heard your pump run was between FP and +B and was installed when the problem reoccurred then your circuit opening relay isn't it.If it cranks and won't start again check for spark quickly while it's doing this and report back. Or if you got it running, update the thread with that
Carlj64
Oct 19, 2016 06:32 AM
DogGrass
Jul 16, 2012 05:57 PM
mattiesmalls
Feb 8, 2009 10:32 AM
lonnie104
Aug 3, 2007 12:23 PM
