92 TOY's 22re / crapped out / gotta start somewhere / thread
Old May 26, 2010 | 05:58 PM
  #3041
vital22re's Avatar
totally a bro
Originally Posted by Lumpy
Hmmmmm interesting...very interesting in deed.
I'm going to have to agree with vital here. Take the rear brakes apart and then get the "not moving piece" to a vice and make it a "moving piece". Looks a bit cruddy in there blow it out with your compressor but be wary of the dust so of the pads are made with asbestos so your not going to want to breath the dust.
Indeed, Spray down the brakes with water to keep dust down and wash it up a little bit.
Old May 26, 2010 | 06:00 PM
  #3042
92 TOY's Avatar
arrrr
i hear ya
Old May 26, 2010 | 06:06 PM
  #3043
vital22re's Avatar
totally a bro
Originally Posted by 92 TOY
arrrr
i hear ya
It'd be a good idea to pull everything apart clean and lube the places that need it. Your adjuster bolt may be frozen so clean and lube that as well.
Old May 26, 2010 | 07:20 PM
  #3044
iamsuperbleeder's Avatar
ew... nice looking brakes there
Old May 26, 2010 | 08:10 PM
  #3045
flyingbrass's Avatar
I'm still waiting for pony pictures. Horses, donkeys and mules are all fine, but those little dinky ponies are worthless at best.
I missed whatever was mentioned about an oil leak/drip. It dripped while up on the lift? If it's oozing from the pan, I'd try snugging up the pan bolts a little. Not much, just a little extra. Of course, if you had pulled the engine, sealing the the oil pan would have been easier.
Ted advises checking/retorquing head bolts after the first run, and again at 500 miles. He told me there is no need to after that. Marlin, OTOH, rechecks head bolt torque each time he adjusts valves.
Several of my head bolts turned a surprising amount after only a few runs (heating/coolng cycles). I checked them again at 300ish miles, and none budged. I'm using Engnbldr's gasket and his bolts torqued to 64 ft/lbs.
Old May 26, 2010 | 08:24 PM
  #3046
PismoJoe's Avatar
Man I'm so glad I live in CA...rust doesn't like the weather
Old May 26, 2010 | 08:44 PM
  #3047
hilandfrog's Avatar
You have me scared about a missing o ring... did I forget to put one in somewhere:eek
Those brakes and the dust the provide make for great lungs, many folks in Liby MT have great lungs:cry
wet the crud down, wear a mask and go easy w/ the compressor.
Repo
Old May 26, 2010 | 09:27 PM
  #3048
ChefYota4x4's Avatar
I thought mine came with that o-ring...I know I had an o-ring and I think I put it there if I'm not mistaken. I could be wrong though and used an o-ring like it elsewhere or used an o-ring for that which should have gone somewhere else.
Did that help???
NO, lol...jk, ...and THAT'S THE BASTARD PIPE that I had to replace! My machinist and the Toyo-Lexus Mechanic I talked to today said "YOU REALLY should use that O-ring, ...the RTV CAN work, ....but if that flange is plum, the o-ring should do it all by itself. Plus, you don't want RTV floating around in the cooling system...be careful". Not trying to freak you out, just sharing what I heard today.
BTW, SO SORRY you're dealing with this new headache, J! Got my fingers crossed and said a 'Rust Loosening Prayer' for ya! lol.
Old May 27, 2010 | 02:28 AM
  #3049
92 TOY's Avatar
g'mornin..
soaked the 2 bolts and other parts of that CRANK BELL thing....what a stupid name...
the one bolt seems conveniently behind the area where the wheel studs are.....i have a sinking feeling about this.
so, once again the FSM , Haynes and Chiltons are mostly worthless for this repair....although it seems fairly straight-forward i'm learning more and more it's very tough to step out of your realm and expect to find any directions for someone who has NFC.
i don't know what you guys are talking about rinsing or anything like that.....it's dusty, not rusty in there....if you mean wash away the dusty stuff, sure, i could do that....just more concerned about getting these levers (bell cranks) removed, cleaned up, lubed and re-installed.
crabby, i'm crabby......i mostly rebuild an engine and i'm thwarted by my frigging emergency brake.
Old May 27, 2010 | 03:12 AM
  #3050
92 TOY's Avatar
OK....I officially say screw this!!
this SST, that SST.....and yes the directions in that PDF are close but not correct for my truck.
VOLUNTEERS?
I'm frigging done with this part of the episode!!!
Old May 27, 2010 | 03:45 AM
  #3051
xxxtreme22r's Avatar
Just did mine, I can help out once again if ya need me this weekend. I still have that brake hardware kit too.
Old May 27, 2010 | 03:47 AM
  #3052
btw you might not even need the self adjusters
Old May 27, 2010 | 03:54 AM
  #3053
92 TOY's Avatar
as per TOYODIY.... i think this just may be the big metal part, nevermind the other parts....
47624B CRANK, PARKING BRAKE BELL, NO.1
47624‑35020 RN10*, 110, VZN10*, 110..JPP; RH 1 $36.50
47625‑35020 RN10*, 110, VZN10*, 110..JPP; LH 1 $36.50
if i cold get the G-D things apart, I probably could refurbish them....from what I read, that's what needs to be done.....it's apparently bound up real good in there.
XXXTREME....I have more stuff I could give away........
Old May 27, 2010 | 05:08 AM
  #3054
lol I'll take the 4runner please. ROFL, before you order ayy parts, let me get that dang thing apart first.
No stinkin SST's needed.
  #3055
92 TOY's Avatar
so anyway...drum is back on, what was unhooked, is hooked back up. truck is out of the garage, parked out of the way....more pressing matters right now, namely have to get one tire for the cadillac to replace the bologna skin one that is on there.....so the cadillac and my truck exchanged places for now...
thought i was gonna get something accomplished today...pic taken about 630am today
1st order of business, besides getting the drum off is to get this pin out...it too was bound up and took a bit of convincing to come out.
cable off and out of the way...spring removed from the back also
here's the 2 bolts that can't be accessed
shortly after examining everything and reading the FSM, realized this is not gonna happen today....so i put it all back together and pulled the cadillac in
this all blows right about now!!!!
Old May 27, 2010 | 05:09 AM
  #3056
I have to watch my 4 year old so I wont be available till saturday though.
Old May 27, 2010 | 05:12 AM
  #3057
92 TOY's Avatar
OK...offer accepted...but i'm gonna be gone most of the day today, so today is out.
tomorrow, working all day...so tomorrow is out.
saturday, have a christening at 11am and then a party for said christening after that....so saturday is MOSTLY out.
sunday....have to be a good guy in the morning (church) and then sunday about 6pm i always have to run down to work and prepare reports....so most of sunday is out.
monday and tuesday working all day
in other words,,,,,GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
Old May 27, 2010 | 05:13 AM
  #3058
92 TOY's Avatar
off weds, thurs, fri next week
Old May 27, 2010 | 05:15 AM
  #3059
92 TOY's Avatar
On a happier note, i did win a CB yesterday on ebay...never used Radio Shack brand trc-503.......$60 new, shipped to me for $22.51....so yay me on that one
Old May 27, 2010 | 05:18 AM
  #3060
Lumpy's Avatar
I feel soooooooo bad for ya right now man!!! That just blows!!!
