92 Toyota With Temp Problems
Old Nov 19, 2006 | 01:47 PM
SCOTTK's Avatar
I Have A 92 Toyota With 545,000 Km {300,000 Miles} That Is Doing Wierd Things In Terms Of The Temp. If The Temp Control Is Set For No Heat The Temp Gauge React As It Always Has. If The Heat Is Turned Up The Gauge Reads Higher Than It Should But Will Reach A High Point Than Drop Back Down To Normal. I Have Had The Thermastat Changed. I Have Not Seen Any Leaks Of Coolant Or Any Thing Like That. Any Idea's Would Be Helpful.
Old Nov 19, 2006 | 03:47 PM
84sr5yoty's Avatar
Temperature gauge overshoot. It's a somewhat common problem on the 22r series motors. Installing the dual stage thermostat (part# 90916-03070) should alleviate the problem.
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old Nov 19, 2006 | 03:50 PM
Jay1's Avatar
I think my 86 pickup my have that problem to let me know how it works for you?
the1998sr5
Oct 19, 2016 12:48 PM
yourrealdad
7
Jul 21, 2015 08:53 AM
BLRobertson
3.4 Swaps
Jul 10, 2015 04:27 AM
Bru
Jun 23, 2015 06:58 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
