What To Do??? Sell It Or Fix It!?!?
Old Nov 19, 2006 | 08:36 AM
YOTAKIMMER's Avatar
Well, once again i've run into another problem and i'm to the point of not wanting to even deal with it. I have a 89 yota pickup that is pretty solid overall for a 89. I have about $650 into so far without the new tires, but ran into another problem while getting the tank out to replace the fuel pump. Basically its gonna need a new sending unit and fuel pickup unit and possible a new tank if you can drill out the small 8mm bolts that are breaking off on the pickup unit. The truck also needs a new break line or a patch line installed where it is leaking. I'm to the point of not wanting to deal with it no more, but it's not a bad little truck. What i've done so far:
installed used 22re with 109,000 miles
new clutch
new cap, rotor, wires, plugs
new air filter
new belts
new radiator
new fuel pump to still put on
What it needs:
I was going to put on two new fenders $30 each
fuel pickup, sending unit possibly, tank possibly
rear brake line repaired
Extras with it:
intake with throttle body
clutch in great shape
altenator
I also have brand new 31x10.50-15 maxxis tires that I paid $500 for, but might use them for my next truck.
What should I do?? Should I just cut my loses and try to get my $650 back or bite the bullet and finish the job? Personally i'd like to cut my loses and just buy something needing tires, but not sure what I could get back out of the truck. I can't afford to lose any money on it. Here's a a pic of the truck. The bed is not rusted out which is why I started this project.
Old Nov 19, 2006 | 08:42 AM
gilby4runner's Avatar
Keep it and fix it. That way you know what you've got. Buy another truck and you might end up spending the same amount. IF you have it just to beat around in and get muddy then its worth fixing.
Old Nov 19, 2006 | 09:10 AM
91_4x4runner's Avatar
Fix it, it's not the most difficult surgery to get a vehicle running.
Old Nov 19, 2006 | 03:25 PM
silversup's Avatar
Fix. you know your problems on this one. Another project will give you unknown problems.
Old Nov 19, 2006 | 04:35 PM
neilan's Avatar
fix i have a fuel tank with everythign inside the tank minus the sender which i used on my runner. It off a 87 4 runner. id sell it for liek 40 bucks plus shipping
Old Nov 19, 2006 | 04:51 PM
YOTAKIMMER's Avatar
I went ahead and bought a brand new tank and i am getting a price on a new pickup....gonna try to save my sending unit. I figure I can't go wrong with new.
Sep 4, 2015 09:27 AM
58rennur4
Aug 4, 2015 08:49 AM
Gone Fission
Jul 31, 2015 03:58 AM
Athansinis
Jul 27, 2015 08:38 AM
sabine
Jul 18, 2015 03:59 PM
