92 Slow blower motor!
Well the blower for the heater in my truck(non ac) is very slow, it appears to be on low through all speeds, i can see the actuall motor too since i dont have a glove box.
what should i check first?
The fan gets direct power from the under hood fuse panel. 10G White wire. The switch in your dash is three different size grounds. I don't really know, there is a relay also. I bypassed everything and had a toggle switch for off/high.
The 'off' position is open.
The 'high' position is high.
The lower speeds have resistors or something to reduce voltage=fan speed.
All the cars i've messed with are wired this way.
I can take a picture of my rig job since i run no dash
Remove the blower, hook it up to straight 12V from the battery. If it blows fast at 12V, it's probably the motor has just gone slow(bad/worn out bushings/bearings, etc); Usually when the resistor goes bad, you lose all speeds except high.
Flying91
45
Apr 11, 2024 04:39 PM
crammit442
7
Nov 29, 2017 12:30 PM
Crgrey42
Aug 10, 2015 04:23 AM
