92 Slow blower motor!
Old Aug 29, 2011 | 12:43 PM
91muddog's Avatar
Well the blower for the heater in my truck(non ac) is very slow, it appears to be on low through all speeds, i can see the actuall motor too since i dont have a glove box.
what should i check first?
Old Sep 15, 2011 | 11:54 AM
91muddog's Avatar
no info on this anyone?
Old Sep 15, 2011 | 12:08 PM
WHAHAHAJR's Avatar
Slow blower motor or no air volume? Does it sound like it making alot of noise but no air flow?
Old Sep 15, 2011 | 12:13 PM
91muddog's Avatar
its not making alot of noise, the motor pretty much just stays on low speed. i dont have a glovebox so i can see the motor
Old Sep 15, 2011 | 12:14 PM
BMcEL's Avatar
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Old Sep 15, 2011 | 12:17 PM
tj884Rdlx's Avatar
typically for any vehicle, a blower fan with only one speed = failed resistor pack. i don't know if your year truck has one. otherwise, fan switch.
Old Sep 15, 2011 | 12:20 PM
91muddog's Avatar
thanks bmcel for the link!
saving that for sure
Old Sep 15, 2011 | 12:31 PM
misaaccooper's Avatar
The fan gets direct power from the under hood fuse panel. 10G White wire. The switch in your dash is three different size grounds. I don't really know, there is a relay also. I bypassed everything and had a toggle switch for off/high.
The 'off' position is open.
The 'high' position is high.
The lower speeds have resistors or something to reduce voltage=fan speed.
All the cars i've messed with are wired this way.
I can take a picture of my rig job since i run no dash
Old Sep 15, 2011 | 09:46 PM
Keith B.'s Avatar
Remove the blower, hook it up to straight 12V from the battery. If it blows fast at 12V, it's probably the motor has just gone slow(bad/worn out bushings/bearings, etc); Usually when the resistor goes bad, you lose all speeds except high.
Flying91
45
Apr 11, 2024 04:39 PM
crammit442
7
Nov 29, 2017 12:30 PM
Crgrey42
Aug 10, 2015 04:23 AM
msane99
Jul 17, 2015 10:13 AM
