92 pick up FULL TUNE UP NEEDS?
Old Oct 18, 2015 | 01:08 AM
davidsalas's Avatar
Just bought a 92 Toyota pick up 5spd 2.4 L 4x4... Looking to do a full tune up, want to make sure I'm running smooth. What should I replace ??? Thanks guys
Old Oct 18, 2015 | 02:15 AM
anndel's Avatar
Plugs, wires, distributor cap, rotor, air filter, Chevron or Red Line or Gumout fuel injector cleaner, maybe drain and replace coolant, oil and filter, check brake fluid, drain and replace front and rear diff gear oil, manual tranny fluid, transfer fluid, grease spider and u joints, check cv boots, check brakes, maybe tires and spare.
Old Oct 18, 2015 | 02:16 AM
anndel's Avatar
Don't forget to check the timing chain if its rubbing on the timing chain cover
Old Oct 18, 2015 | 02:19 AM
bipolarandproud's Avatar
Check/Adjust valves.
Old Oct 18, 2015 | 07:25 AM
Terrys87's Avatar
Clean Intake and check if vacuum lines are in great shape and routed correctly.
Matt89toyota
Jun 27, 2023 08:00 AM
ZGjethro
Jun 7, 2017 11:04 PM
moparbay
Oct 6, 2015 09:24 AM
mluz013
Sep 29, 2015 05:53 PM
