92 4Runner Won't Start After Arcing Wires
Old Jul 6, 2017 | 05:36 AM
nowhere's Avatar
I have a 92 v6 4wd that turns over, but will not start. The check engine light does not come on when the ignition is on. Vehicle turns over but will not start.
The story begins with a busted headlight after hitting a deer. I replaced bulb and it was still very dim on the passenger side. At first I began looking for a broken wire, before I realized I just had a fuse problem. While I was inspecting wires I was unwrapping the tape around the wiring sheath that sits behind the battery over the passenger side fender. There were 3 white wires with a red stripe that had a connection there that was crimped and had a plastic cover over them. As I unwrapped tape the some of the copper wire became exposed and I bumped it against the fender and it arced the wires against the fender. Since that time vehicle will not start and CEL will not come on with ignition on.
All fuses are fine. I checked the voltage at B+ with key on I get nothing. Swapped the headlight relay with EFI relay, no difference. Check voltage of ECU fuse on driver side kick panel with key on and I have 12v. Check voltage at ignition fuse with key on, I have nothing.
I checked voltage on the same white wire with red stripe that I zapped and have zero volts there.
In the process of being a careless idiot, did I fry the igniter or the ignition switch? I don't have much experience with tracking down electrical issues. This a daily driver that gets my son to work and I need to come up a solution as soon as possible.....getting a bit desperate. So any advice would be greatly appreciated.
Thanks
Old Jul 6, 2017 | 08:46 AM
RJR's Avatar
RJR
In looking at the wiring diagrams, it seems very likely you blew the 30 amp AM2 fuse, which is in the fuse box under the hood on the passenger side. That powers up the ignition fuse, but not the starter circuits or the ECU fuse. It also has a white-red wire associated with it, so it matches all of your observations.
Old Jul 6, 2017 | 09:11 AM
RAD4Runner's Avatar
Originally Posted by RJR
In looking at the wiring diagrams, it seems very likely you blew the 30 amp AM2 fuse.
This^^^.
Also supplies the 15A EFI fuse.
