91 Toyota 4 Runner with a 3VZ-E has a miss, rough idle, won't start in cold weather.
Old Dec 7, 2013 | 11:45 AM
DB3's Avatar
DB3
91 Runner with 3VZ-E has a miss, rough idle, turned idle/screw up so it wouldn't die when coming to a stop, and now will not start in cold weather unless pull started. It is freshly rebuilt with new timing belt, plugs, wires, cap and rotors, and injectors. Timing is set at 10 degrees BTDC. It has spark. It also when running at highway speeds will surge only once. But will do it periodically throughout a trip only at highway speeds never in town.
Old Dec 7, 2013 | 11:58 AM
Cyberman's Avatar
Verify cold start injector is working, check that wires are hooked up correctly.
Yont283
Sep 23, 2022 08:06 PM
newzingo
Jun 24, 2015 01:50 PM
slider417
Jun 22, 2015 10:18 AM
BTOWN4RUNNER
Jun 16, 2002 06:08 PM
