91 pickup clutch problem
I have been working on my new truck and i had problem with the clutch cylinders. I bought both of them but now i noticed that the fork is cracked. How can you remove the fork, is it possible without removing the transmission?
thanks
thanks
wow! how's that happen, you suppose?
looks like it's cast metal. so, yeah...you could have that welded and then reinforced
is there any fore and aft adjustment on the slave cylinder?
Well that was my fault, i was waiting for the master cylinder and i had to move the truck...trying to get it in neutral i tried to move the fork with pliers
not a good idea. Im not proud of myself, haha. I will weld it this week end, it shoud be ok
