91 ext cab up and quit, need a little help
Old Sep 28, 2007 | 06:35 PM
Soupertoy's Avatar
UPDATE Son was driving his (my) 91 V6 to school and it just quit, it will crank just fine, no start. I figured it was the timing belt but the rotor turns...good sign so far.
Any thoughts from ya' all.
Thanks,
Old Sep 28, 2007 | 06:43 PM
thook's Avatar
See if you're getting fuel. There's a relay for the fuel pump that can go just like that. Then, there's the fuel pump itself. Check for spark, too.
Check to see if there are any CEL codes while you're at it.
http://www.off-road.com/toyota/tech/codes/
Old Sep 28, 2007 | 06:45 PM
thook's Avatar
Wait...let me be a little more specific.
If you turn the key to ignition, you should hear the fuel pump running. Can you?
Old Sep 28, 2007 | 08:59 PM
jasond's Avatar
The fuel pump does not run unless you are cranking the engine, the engine is running, or you jumped the fuel pump terminals of dlc1 / opened the afm door
Old Sep 28, 2007 | 10:50 PM
notanymore's Avatar
just a thought, check all your fuses, maby the fuse on your fuel pump poped or somethings, rember to check the ones behind the kick panel on the driverside
thook's Avatar
Yes it will....albeit only for a few seconds. But, good that you brought this up.
Soupertoy...
If you don't appear to be getting fuel, jump the terminals "FP" and "B+" at the diagnostic box and turn the key to ignition. This will bypass the relay switch and the VAM....."hardwiring" the fuel pump. The FP should run continuously now (as jason is saying) and be audible. If it doesn't run, then it's toast. If you can hear it, try and start the vehicle. If the vehicle will run at that point, then there's a problem in the relay or the VAM.
Old Sep 29, 2007 | 09:47 AM
Soupertoy's Avatar
Well, checked the fuses and the EFI fuse was blown, tried another x2 and blew them too, any ideas??
Thanks for the help.
Old Sep 29, 2007 | 10:01 AM
4JOGGER's Avatar
Check O2 Sensor wires...make sure it's not leaning against exhaust pipe and that it does not have a short
Old Sep 29, 2007 | 10:13 AM
Soupertoy's Avatar
O2 sensor is good, disconnected it, put in new fuse...turned the ley to IGN and the fuse blew again...gotta be something easy..it has 139K miles on it no probs till 2 days ago.
Thanks again
Old Sep 29, 2007 | 01:16 PM
Soupertoy's Avatar
Well it started, new fuses, cleaned battery terminals, and it started right up, taught the boy where and how to swap out the fuses.
THANKS FOR THE INFO,
Soup
Old Sep 29, 2007 | 05:31 PM
thook's Avatar
Are the wires down in the fuse box good and tight? Any corrosion? Do you have a good ground from the battery to the vehicle body?
Old Sep 30, 2007 | 08:01 AM
Soupertoy's Avatar
Yep, so far good to go, thanks again.
Old Oct 2, 2007 | 05:21 PM
timebandit's Avatar
EFI fuse? That could be anywhere. The EFI relay sends juice into the fuel pump (CO) relay and the VSV's on the valve cover, and the Ho2 sensor and the AFM. If you have a 12v test light than put it into the dead leg (load side) of the fuse and the clip to the battery positive and start unplugging stuff 'till the light goes out or gets dim. If it is bright, that is the short.
Old Oct 3, 2007 | 10:53 AM
n4ynu1010's Avatar
Motor won't start
If you had this problem after a drive in the rain you might want to check and make sure you do not have the windshield leak problem getting the ECU connector wet in the passenger side kick panel , this has been a problem on some trks in previous posts .
If you are getting water draining/leaking in the passenger floorboard when raining it could be the windshield or possibly your cowl vent drain is stopped up thereby not draining and then coming in at kick panel raining down on ECU connector as well .
JustMike
Apr 21, 2016 07:08 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
bobpat
Aug 1, 2015 09:25 PM
pyramid
Jul 29, 2015 06:53 AM
Nickdigg
Jul 7, 2015 06:04 AM
