91 3.0 major oil leak
Old May 28, 2006 | 03:35 PM
fj4031003's Avatar
Unhappy 91 3.0 major oil leak
Just got back from a 80 mile trip doing 80 MPH. When I got home I noticed oil all over the bottom of the truck. I pulled the lower plastic cover and think I traced it back to the front seal area. Is this common? Any other area in the front of the motor that could cause such a major leak? The PCV has never been changed its a 3.0/Auto 4x2. HELP!!!!!
Old May 28, 2006 | 04:35 PM
mr toytech's Avatar
you have the front crank seal there and the oil pump. you may need a new pcv valve but the seal is probabley the cause.
Old May 29, 2006 | 05:54 AM
fj4031003's Avatar
Could it need a new pump or just the pump seal? Its time for the timing belt replacement anyway is the front seal replaced with this service?
Old May 29, 2006 | 06:02 AM
Elton's Avatar
every thing has to come off the front of the motor when doing a t-belt i would replace the seal and get a new pump better than haveing the old one fail and over heat the motor and blowing the hgs and costing you more money
Old May 29, 2006 | 06:22 AM
fj4031003's Avatar
Thanks I should change the pump too. Have you heard of oil pumps failing on these motors?
Old May 29, 2006 | 11:24 AM
Chuki's Avatar
No need to do your oil pump, water pump might be something you should change though.
One way to tell is spin the waterpump by hand, if it spins freely I'd replace, but if it has some resistance when you spin it, then I'd leave it alone.
Resistance when turning pump means the shaft seal is still good, no resistance (free spinning pump) shaft seal is worn, may not be leaking yet, but wouldn't be a bad idea to change the pump.
Old May 30, 2006 | 07:42 AM
jjenks0's Avatar
Could be your oil cooler on the drivers side of the engine. Looks like a big metal canister. There is an oring in there that goes bad. I did mine a couple of months ago.
Old Jun 1, 2006 | 12:25 PM
Reldnew's Avatar
What he said above. Mines leaking (slowly) right now just gotta find the time to fix it.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
