91 3.0 intake problem?
Old Apr 28, 2018 | 04:39 PM
Rooster54's Avatar
wondering if anyone else has had problems with their vehicles involving the air intake. My Runner runs rough, hardly any power. It’s definitely fuel related because it runs super rich, so I know it’s not the fuel pump, there’s no gas in the vacuum line on the fuel pressure regulator so I don’t have a reason to believe it’s that, brand new spark plugs and wires and distributor looks just fine, and I read something online that it could be problems with/partially clogged. The vehicle sat for few years so it wouldn’t surprise me if something got sucked up in there. Just looking for some ideas, thanks.
Old Apr 28, 2018 | 05:24 PM
Drewandhis89Yota's Avatar
Does it have good spark. My truck had a Spark that wasn’t constant when I put a spark plug tester on a plug wire. It was a very random kind of spark and it was running rough. Tried a distributor I had laying around and presto smooth idle/spark and no more surging at 1/8 throttle. Also when I put a timing gun on it the span of the mark was like 30 degrees it was hopping around. Now it only varies about 3 or 5 degrees with good distributor. My intake makes a funny groggy sound once and a while that’s why I clicked on this thread. If it’s not the dist. Maybe clogged injectors or evap leak. Is there a hissing sound? my pcv hose was loose and leaking so I replaced it the other day but it didn’t really make a difference.. that was before I replaced the dist.
Old Apr 28, 2018 | 05:25 PM
I think the afm has a code it will throw
Old Apr 29, 2018 | 04:23 PM
Rooster54's Avatar
Yeah good spark, but yeah it kind of has a hissing sound but I couldn’t find any leaks, and I’m in the middle of taking the intake manifold off and cleaning it and will look at the injectors too.
Old Apr 29, 2018 | 05:34 PM
Do you have a Haynes manual? did you get the old gas out of there? Fuel filter clogged, timing, spark plug gapped incorrectly, I just got new denso spark plugs and only one of them was perfectly gapped. clogged fuel lines. Do a fuel pressure test. Compression test. maybe advance the timing a little and see if that helps. But advancing the timing may just mask the problem. Get a timing light on it to be sure. I have mine like 3 degrees advanced.
Old Apr 29, 2018 | 06:52 PM
Rooster54's Avatar
no manual, bad gas is gone, new fuel filter which was broken and had tons of dirt in it, new plugs and wires which didn’t change after that, and I’m gonna look at the timing while I have the manifold off too, it’ll be much easier to take the cover off without all those hoses and stuff, thanks!
89whitetoyota
Nov 10, 2008 11:21 AM
4rnr
Sep 15, 2006 06:31 PM
DN1911
Jul 25, 2006 06:57 AM
BOSTON4RUNNER
14
Nov 17, 2004 07:00 AM
