90 p/u 22re codes 25 26 41
Old Apr 19, 2011 | 09:39 AM
xalier's Avatar
like it says my 90 p/u 4wd with 22re has the check engine light one and i did the code check and came up with 25 26 and 41... it has a fairly new o2 sensor and i just replaced the tps with a used unit.. my question is what has you guys found to be the problem with these codes? any help is greatly appreciated
Old Apr 19, 2011 | 09:56 AM
4Crawler's Avatar
What sort of O2 sensor (brand)? Did you test either the old or new TPS?
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
If all OK, check wiring between sensors and ECU. Best sensor(s) in the world do squat with bad wiring.
Old Apr 20, 2011 | 09:58 AM
xalier's Avatar
ya i tested them but my pos multi meter im unsure if it was reading correctly or not
MMA_Alex
25
Apr 18, 2017 05:07 AM
montanatruck
Feb 26, 2017 07:07 AM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
Jul 24, 2015 06:29 PM
jake_v
Jul 22, 2015 03:17 PM
