90 4Runner V6 Engine doesn't run after power washing
Old Mar 14, 2010 | 05:48 PM
Jeremy11's Avatar
I removed my egr valve and my engine started up. i power washed it and now it cranks and sputters but doesnt completely turn over.
I now replaced my spark wires, distributor cap and rotor and my spark plugs are good.
Any ideas??
Old Mar 14, 2010 | 09:41 PM
Jay351's Avatar
Have to checked for spark?
Old Mar 14, 2010 | 11:01 PM
DeathCougar's Avatar
Doesn't turn over? Or doesn't fire.
Old Mar 15, 2010 | 08:29 AM
Jeremy11's Avatar
I have spark. And it seems like im lacking fire. It cranks and sputters like it wants to turn over but there is something that isnt there to complete it.
If that makes sense
Old Mar 15, 2010 | 08:49 AM
Again....doesn't turn over? Or doesn't fire/start?
There is a BIG difference.
Old Mar 15, 2010 | 08:53 AM
Jeremy11's Avatar
it doesn't fire/start. It has new dist. cap, rotor, wires, and the spark plugs are fairly new.
Old Mar 15, 2010 | 09:36 AM
Are you getting spark at the plugs?
Remember, engines need 4 baic elements to run. Fuel, Air, Spark, Timing.
Start with the basics.
Old Mar 15, 2010 | 09:44 AM
MrPeepers's Avatar
ALmost every time I have seen this it's been water in hte distributor. There is some spray you can buy at Pep Boys, etc that is made to dry out electricals.
Old Mar 15, 2010 | 09:55 AM
toy4run's Avatar
WD40 will also dry it out. Did you pressure wash it with the motor running. Check you air filter. If its wet replace. If its wet you've got water in your motor. Your mass air flow sensor will be wet and need to dry to give accurate reading to computer. A blow dryer can do this put keep on low setting. If so, remove plugs. Turn the engine over with spark plugs removed. This will push water out of heads through the plug ports. Also have oil changed if thats the case. Check your coil for voltage, make sure its still putting out like an old girlfriend. replace everything and try again. Good luck.
PS. Does it at least look clean? How well did it work? I am close to needing to pressure wash mine as well.
Old Mar 15, 2010 | 11:23 AM
Jeremy11's Avatar
I've got spark
How do i know if there is water in the distributor?
i pressure washed it with the motor off. Where is my coil? Could it be possible if my ignitor got wet?
Haha yeahh it looks cleaner than it did before. but before it was caked with mud.
Old Mar 15, 2010 | 07:03 PM
4x4runr's Avatar
Check the fuses too. I had the same problem where I had spark and changed everything.... dang fuse....
Old Mar 15, 2010 | 08:20 PM
Jeremy11's Avatar
Got it all fixed up! Thanks guys!
Old Mar 15, 2010 | 08:35 PM
And this would be where you tell us HOW you fixed it...
Old Mar 16, 2010 | 10:59 AM
Jeremy11's Avatar
Well dont i fell pretty stupid. I had a little water in the plugs and it turns out my wires were set up backwards. After i quadriple checked they were backwards. So i just got the water out and fixed my wires.
Old Mar 16, 2010 | 11:49 AM
AkitaDog's Avatar
As Homer would say! DOH!
Old Mar 16, 2010 | 12:07 PM
MrPeepers's Avatar
I did that on my old 65 Mustang, except the Mustang started. I drove down a hill and noticed it misfiring, so I turned around and going back up the hill and it started misfiring much worse struggling to get up the hill, then pulled an "Uncle Buck" and made a bang that sounded like a gunshot and blew something metal out my exhaust, I heard it hit the street.
Old Mar 16, 2010 | 12:21 PM
thedanned's Avatar
I've had some of those "Damn Im an idiot" moments too...
When I built my first VW motor, I had the rotation on the dist cap backwards and the engine RAN!! Not well of course, but the dang thing ran. It would build up so much fuel in the exhaust that every ten seconds or so I would get a huge bang and small flames would shoot out of the pipes. It was awesome.
Old Mar 18, 2010 | 01:10 PM
Jeremy11's Avatar
Good to know i'm not the only one. Lmao
Jun 1, 2021 01:51 PM
he's gone
7
Dec 3, 2019 07:08 AM
alimant100
Jan 20, 2016 05:58 PM
scooba
Aug 25, 2015 09:49 AM
GeoRoss
Jul 24, 2015 03:03 PM
