89 toyota sr5 22re ac works but ....
Old Mar 25, 2010 | 05:39 PM
waynesworld's Avatar
i have a 89 toyota sr5 excab 4x4 22re with air condition.it works fine when im driving .but when i stop and idle it wants to cut off .isnt their some kind of switch or something that i can replace .
Old Mar 25, 2010 | 07:20 PM
yayfortrees's Avatar
Is the blower motor cutting out, or does only the A/C compressor cut out?
If it's the compressor, there are not any switches that I know about that would fix this problem. If it's the blower motor (the fan) cutting out, it's likely the resistor switch, or the motor itself. If it's not the fan motor -->
1st: Visually inspect the belt (condition and tension) and A/C clutch with motor off. Then inspect the A/C clutch at idle, with A/C off, then on. If that looks good ->
2nd: Check the refrigerant pressure. (Or have it checked at a shop.) If that is good ->
3rd: Inspect the compressor/condensor.
Old Mar 25, 2010 | 07:32 PM
myyota's Avatar
If you remove the glove box there is an idle control box mounted on top of the a/c unit under the dash, you can adjust it a little until you get the a/c to stay on at idle.
Old Mar 28, 2010 | 03:26 PM
Talking 89 excab sr5 22re ac works but ....
hey, sorry i have never gotten back with y'all im new 2 this site .thanks 4 the information .
i didn't know about the glove box adjustment thanks im gonna try it next week .thanks again.
Old Mar 29, 2010 | 07:00 AM
hgill's Avatar
I had the exact same problem where my compressor clutch would not engage while idling and would work when driving(high rpm).
To fix it, I had to turn a knob on the located on top of the Cooling Unit. It is located behind the Glove Box. Just turn the knob to "LOW".
Here is how it looks like:
Old Mar 30, 2010 | 05:00 AM
abecedarian's Avatar
First I'd check the a/c idle up is working properly- too low idle speed with the compressor on could cause the compressor to cycle. Then I'd check the refrigerant charge- a low charge could cause the pressure to fluctuate a bit at idle possibly tripping the low-pressure cut-off switch.
Old Mar 30, 2010 | 01:01 PM
89 sr5 4x4 excab ac works but ...
hey, the blower motor is working fine . the only time the ac comp. kicks off is when the idle speed gets 2 low.
what is the ac idle up? abecedarin. kool pic of the ac outside .
DacodaYota
Sep 2, 2015 02:13 PM
gog1968
Jun 22, 2015 05:55 AM
