89 offset
It depends on how wide of a stance you want for your truck. I prefer around a 3-3.5 inch backspace because I like the wider stance for stability. Someone might chime in with the factory backspacing, but if you want to measure it yourself, take the tire off and lay the rim face down, then place a flat edge across the diameter. Take a tape measure, and measure from the lug location to the flat edge.
timber725
124
Jun 7, 2004 07:39 AM
