'89 4Runner + server rack + old pickup cap =...
Old Mar 2, 2007 | 05:32 PM
  #141
Rather Diesel's Avatar
Here is a pic from their site.
Old Mar 3, 2007 | 12:37 AM
  #142
Elton's Avatar
looks sweet
Old Mar 5, 2007 | 10:39 AM
  #143
aviator's Avatar
Just reviewed some old posts...
so by going with the divorced transfer case I assume you are keeping the benz-o-matic? or was the divorce required by the engine swap?
and you are still debating the slush/manny tranny question?
the plate looks like a tough as nails part though.
can't wait to hear more...
Old Mar 5, 2007 | 12:33 PM
  #144
I swear, at some point, I'll make my own adapter to use the Toyota 5-speed, if I can't get the divorce adapter. I'd probably get better MPG with the manual, but I thought the Benz-auto would be easier.
Maybe I'll get my adapter soon.
The redesigned interior is coming along well now. If I don't get the adapter by the time I'm done the rest of the truck, I may try to make my own. We'll see.
Roy
Old Mar 5, 2007 | 12:41 PM
  #145
aviator's Avatar
What would be required to use the manny tranny is it just a flat plate to adapt the boltholes or is a more three demensional thing required?
Old Mar 5, 2007 | 01:25 PM
  #146
It is more of a plate than 3D. The shafts engaging each other is a different matter though. I may need a custom gear and bushings for that. If I tackle the adapter, I need to get a trans. I traded the old auto-trans for a gear-drive T-case.
Roy
Old Mar 6, 2007 | 08:41 AM
  #147
jagger_snitt's Avatar
Man,I thought you gave up.. It is like you were telling this awsome story and then you did a month long dramatic pause. Keep us posted. I'm envious although I love my baby. Keep up the good work looks great so far.
Old Mar 6, 2007 | 08:50 AM
  #148
mastacox's Avatar
We need pics of the new interior!!!
Old Mar 6, 2007 | 09:54 AM
  #149
Here are the drawings for the new interior. Actual photos don't show much. It's just a jungle of 1/2" square tubing.
Attached Thumbnails '89 4Runner + server rack + old pickup cap =...-above_final.jpg
Old Mar 6, 2007 | 09:55 AM
  #150
another
Attached Thumbnails '89 4Runner + server rack + old pickup cap =...-driver_doors.jpg
Old Mar 6, 2007 | 09:57 AM
  #151
I need to re-size the other drawings. The files are over the limit.
Roy
Old Mar 6, 2007 | 09:58 AM
  #152
aviator's Avatar
Looks pretty sweet RD
Old Mar 19, 2007 | 05:31 AM
  #153
Any updates?
Old Mar 19, 2007 | 11:44 AM
  #154
Quite a few updates coming soon.
Roy
Old Mar 20, 2007 | 08:37 AM
  #155
Yaaaay!!!
Old Apr 17, 2007 | 12:37 PM
  #156
sandcruiser's Avatar
You could get away with a smaller inverter if you make sure you never run the fridge and the microwave at the same time. Smaller inverter=less wasted power as heat and it would also mean that you aren't putting as much draw on the battery at any one time (less V drop through cables).
If you set up a 3way (double pole, double throw) switch on the power lines to the fridge/inverter, you could make it so that up=fridge, down=micro and middle=off or something.
that would also be good in that most microwaves try to run a little clock or something similar and there is no good reason to suffer that extra load unless you are cooking.
still, I would look at a propane fridge. We ran one for months and months off of a small bottle (10lb? I think- about half the bbq size). In the end, the propane fridge + propane is a lighter than carrying a genny, and you can cook off of the stove as well (and /or you can use the propane for a lantern, which is nice) You can get propane just about anywhere in North America, and it is widely available in larger towns/cities in Central/South America. I suspect that it is easy to find in other places too.
We did try to use an ARB fridge for a few weeks... it works FANTASTIC if you are driving every day. But in a hot climate (inside the truck is usually warm if you are somewhere sunny), that fridge would draw down a deep-cycle battery in a day or two. Running the truck for a "little while" doesn't do much to top off the battery either, you've gotta give it some serious time... so you end up blowing through a bunch of fuel just to keep your beer cold.
Most propane fridges will also run on 12v (though poorly) or 110/220 volt A.C. power. So if you have "shore power" you can save propane and when you are driving you can save propane by running on 12v.
Another thought: since you've got so much fuel capacity, you may find that you can get away without using both of the jerry cans on the rear for fuel. Maybe use one for drinking water? FWIW: yellow cans are usually used for diesel. Blue for water.
On the topic of water: if you keep your water storage in 5gal incriments +1, it is easy to get good water just about anywhere. By 5+1, I mean 6, 11, 16, 21... etc. That way, when you are down to your last gallon you can refill the container with another 5 gals. Any store just about ANYWHERE carries 5gal containers of drinking water (like the water cooler type). Sometimes, those water containers require a deposit to buy the bottle, so you just buy it, dump the 5gals into your own container, then return and are on your way.
With both fuel and water it is always nice to have some container that you can transport, not just hard mounted tanks. What happens if you run out of fuel/water just a few hundred yards from the gas station? Or, what if you are parked/camped and someone else offers to run into town for fuel/water? Nice to be able to send a jerry can or water container with them... also nice to be able to lend out your portable container to someone else in need.
ok. Nuff outta me for now. Great buildup.
Steve
Old Apr 17, 2007 | 04:40 PM
  #157
Wow, thanks for all the input. It's greatly appreciated. I just started a new job today, so my update on the build will be this weekend. The interior layout is now completely different than the first (two) times I did it. I'llgive more details then.
Roy
Old Apr 22, 2007 | 01:47 PM
  #158
jdsherr's Avatar
similar build-up
rather
great thread! I'm doing a similar project with less rigor over at Ih8mud- haven't posted any pics yet, but have finished the demo of removing the cab on my ride- an 84 fj60 landcruiser- lots o rust.
http://forum.ih8mud.com/showthread.php?t=138754
should have some drawings up real soon- i'm slow as all get out.
love to confer with you sometime on the deisel swap/engine choice- i've been looking at toyota deisels, didn't even think of the 'cedes. do you know pros/cons?
really nice looking fabrication work-
cheers
Old Apr 22, 2007 | 02:14 PM
  #159
EUROJulian's Avatar
Man! Very impressive.,
Old Apr 22, 2007 | 02:35 PM
  #160
TNRabbit's Avatar
Wow, can't believe this is still going! There is much anticipation on YotaTech for your finished product! FANTASTIC JOB.
BTW; your frame extensions look INCREDIBLY ROBUST! Holy Cow, they're thick!
