88 yota not running right
Old Dec 18, 2010 | 06:10 PM
Pig-ota's Avatar
He guys im new to the site , hope yall can help me out with a problem. Let me first say that this is my first EFI toyota i've always had carb's so im not up on all the electronics on this truck. I've got a 88 22re that i rebuilt the motor in and when i first cranked it up it fired right up and will run good for a few minutes (2-3) and after that it starts sputtering and will cut off, almost sounds like it is starved of gas. It seems like when the cold start injector cuts off it starts running bad, i don't know how long the injector runs when first cranked up?.... I don't know if it is the fuel pump or what, hope this makes sense to yall. Thanks
Old Dec 18, 2010 | 06:14 PM
quiggs12's Avatar
What is your idle speed set at? What exactly is it doing after the initial 2-3 minutes? Is it surging?
Old Dec 18, 2010 | 06:18 PM
Pig-ota's Avatar
When i first craks up its idled up to much then it drops down to normal idle then starts sputtering and shuts off
Old Dec 18, 2010 | 06:28 PM
quiggs12's Avatar
Have you shorted out your diagnostic termials (T and E1) to check for codes?
Old Dec 18, 2010 | 06:32 PM
Pig-ota's Avatar
No haven't done that , what do you do jump a wire between them ?
Old Dec 18, 2010 | 06:36 PM
muddpigg's Avatar
Changed out the fuel filter yet? Easy, well with small hands, but might be a good place to start.
Old Dec 18, 2010 | 06:38 PM
Pig-ota's Avatar
Yea did that , didn't help
quiggs12's Avatar
Use a paperclip!
the1998sr5
15
Jul 14, 2020 08:35 PM
Regency
20
Jan 3, 2020 07:43 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
