88 3VZE 5speed- real main seal cover removal-HELP
Old Apr 4, 2020 | 11:10 AM
MichaelL726's Avatar
I can’t get the cover off! I see the bolts coming through the pan. If I Pry a bit I can get the cover over the tabs on the side but I’m afraid of too must pressure at that angle will break cover or not allow the cover to move up. Those bolts through the pan are snug- like no room between pan and bolt- like it’s threaded through the pan?? There’s got to be a tip or trick to doing this… Other than dropping the pan? Which looks like according to my reading you have to drop the front suspension?
Old Apr 5, 2020 | 10:12 AM
Jimkola's Avatar
YT Community Team
5 Year Member
No, the oil pan isn't threaded. Maybe you could double nut the stud and unscrew them to get them out of the way. Those studs are removable/replaceable ( 90116-06119)
4by4yoter
Jan 30, 2016 09:50 PM
d-wood
Jan 21, 2016 06:11 AM
cgeorge
Feb 21, 2010 07:04 PM
coonhound
Nov 18, 2009 11:22 AM
AllCammedUp
Jul 13, 2003 06:38 PM
