88 22RE RWD Power Steering into 93 22RE IFS 4WD?
Old Dec 24, 2015 | 08:10 AM
grotto's Avatar
I'm looking to install power steering into my stock 93 22RE IFS 4WD which is currently manual, so I need a complete system. There's a guy local to me parting out an 88 22RE RWD with power steering that I was hoping to pull for my truck. I looked up some part numbers and none of them are the same, this has me wondering which, if any parts can be swapped to my truck. I assume the pitman arm is incompatible, but what about the gearbox, and the rest of the system? I'd prefer to pull an entire system from a donor truck rather than piecemeal it, but if I can pull the system from this 88 RWD and only need a part or two that would be OK. My truck already has an unused crankshaft pulley so I'm thinking it can be used.
BTW, I tried searching without any luck. Since we like pictures, here's my engine bay:
Old Dec 24, 2015 | 01:24 PM
Robert m's Avatar
Box is different. The parts that I know of that are compatible between 2wd and 4x4 is the pump and bracket, the crank pulley, and reservoir. Not sure about the hoses and lines or the steering shaft.
arcteryx
Nov 1, 2015 03:32 PM
greg944
Oct 7, 2015 05:19 PM
Obmi
Oct 4, 2015 11:30 AM
Shagool22
Sep 28, 2015 07:53 PM
gentry
Sep 28, 2015 06:16 AM
