88, 22re died need help!
Old Jul 21, 2010 | 06:17 PM
hensley88's Avatar
I was driving my truck and it started runing lean and idling high and acted like it was runing out of fuel then it died I thought the fuel pump went out so I changed it, so now I have fuel and spark but it don't run, the tps tested good and the mass air flow tested fine, no check engine light, need help please.
Old Jul 22, 2010 | 04:14 PM
84 yota ex-cab's Avatar
How do you know it was running lean when it died? I guess just start off with the more simple obvious things. I would probably check the plugs, wires, rotor, fuel filter, maybe injectors, that type of thing. If you havent checked out the fuel filter yet, i would look into replacing that. Maybe you sucked up something and it clogged it up...
Just a thought
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
87toyy
Aug 4, 2015 04:51 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
