87 4Runner IFS - Upper Arm Shaft position question
Old Nov 7, 2020 | 03:31 AM
CCDave's Avatar
I replaced bushings in the upper control arms on my 87 4Runner and torqued and staked the nuts on the shaft. I just noticed the shaft on the right control arm is rotated about 10 degrees compared to the left control arm. When torqueing the nuts, the shaft must have rotated on me. Before I move forward on the suspension reassembly, should I remove one control arm and correct the rotation of the shaft so it's position is the same as the other? Or will this correct itself once under load?
Pic below is just a visual reference showing the shaft position difference between my L and R control arms.
Old Dec 11, 2020 | 03:55 PM
CCDave's Avatar
To close this out and for anyone else that may wonder the same in the future, the upper control arms rotated and settled into position.
Here's a pic I took during the final day of restoring the suspension (87 4Runner)
nick9455649
Aug 29, 2015 02:08 AM
geeq
Sep 2, 2010 04:10 PM
4x4YOTA
Jan 21, 2008 02:08 AM
david in germany
18
Sep 11, 2003 09:53 AM
