86 PU CLUTCH..need some advise
Old Jul 15, 2006 | 08:54 PM
haywyre's Avatar
Bonehead question but..I am not sure how to orient this new aftermarket clutch that I am attempting to install. There are no tell tale directions such as "This side toward Flywheel" that would make it simple.
What I would like to know is which face of this clutch disk goes toward the transmission. The variable seems to me to be how high above the disk's surface the springs are set. On one side the springs are essentially in the same plane as the disk on the other side the springs are a full 1/2" above the face of the disk.
I do not want to do this twice so I came to you guys.
Thanks,
Haywyre
Old Jul 15, 2006 | 09:37 PM
84sr5yoty's Avatar
The raised spring side goes towards the trans. The flat side (or flatter I should say) goes towards the flywheel.
Longbed 90
Mar 11, 2019 12:38 PM
Project90
Sep 24, 2015 11:40 PM
seab1209
Sep 3, 2015 05:41 PM
billkmiami
Sep 1, 2015 06:47 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
