86-95.5 Drive shaft Q?
Old Jun 28, 2013 | 09:30 AM
stock87's Avatar
Did these trucks ever come with a boot for the slip joints on the drive shaft to keep them from slinging grease absolutely everywhere?
I just did the clutch on my 87, and I could probably scrape off several pounds of the stuff off the underside of the cab. Every time I grease the rear one, a bunch slings onto the catalytic converter and smokes like hell for a few miles, too.
Old Jun 28, 2013 | 09:40 AM
vasinvictor's Avatar
I guess you realize you are using too much grease. It might be damaging your pinion bearing also using that much grease. I've never had such a problem with no "boot". Perhaps your splines are worn way down?
Old Jun 28, 2013 | 09:50 AM
thefishguy77's Avatar
Don't separate your splines to check for damage before marking them for realignment. It can unbalance your driveshaft and do evil things.
And mine slings a little grease but usually only if I put a lot in. Like after I go stick it in the mud. I pump a lot of grease anywhere I can to replace lost & help clean joints. Not sure if I am doing damage or not with to much grease, but time will tell.
Old Jun 28, 2013 | 12:03 PM
wyoming9's Avatar
Talking
I think your using to much grease .
I never had major problems with grease slinging out like that
Old Jun 29, 2013 | 12:29 AM
Punchy's Avatar
They always do.
You can use a thicker grease, Doesn't sling as much.
I just did mine (used replacement pilot shaft) with lithium grease to just push out the old stuff and it was everywhere.
I will redo it again soon with a nice molly before heavy use.
Old Jun 29, 2013 | 12:32 AM
wyoming9's Avatar
Red face
If your using the right grease it shouldn`t be doing that
Then again I guess how worn things are comes into play.
Old Jun 29, 2013 | 04:01 AM
Toyota~Boy's Avatar
To answer the original question: yes they came from factory with a boot on them
Old Jun 29, 2013 | 06:06 AM
stock87's Avatar
I guess I should clarify, the several pounds are from 25+ years of buildup, not from one greasing.
Still, it's annoying, and if there was a boot on there, I'd love to get one back on. Off to the parts program!
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
