86 4x4 Washer Fluid Reservoir
Old Aug 26, 2020 | 03:52 PM
dogonfr24's Avatar
My sister inlaw needs a windshield washer fluid reservoir because hers is leaking. It appears they are NLA, does anyone know where to get a after market or used on especially in the Yakima Washington area.
Old Aug 26, 2020 | 04:10 PM
Mr. Z.'s Avatar
I recently found one in a local pick-n-pull...
Not a bad place to start looking.
Cheers
Old Aug 26, 2020 | 05:03 PM
dogonfr24's Avatar
Checking, thank you.
Old Aug 27, 2020 | 03:08 PM
95YotaPickup's Avatar
Not sure what the Toyota scene is over on that side of the mountains, but over on the west end of the state there are always folks parting out rigs on craigslist and marketplace. Might keep an eye on those sites.
Old Aug 27, 2020 | 03:12 PM
dogonfr24's Avatar
Thank you I'll take a look Westward.
Blueman's Avatar
If it's just leaking, I'd imagine it could be repaired. They're not particular fancy. Likely it's a crack, and you can use a sealant to fix it.
Old Aug 27, 2020 | 03:35 PM
dogonfr24's Avatar
Saw a couple videos on that using epoxy glue. That seems somewhat brittle, any advise on what to use to seal a crack?
Old Aug 27, 2020 | 03:40 PM
dogonfr24's Avatar
One vid used epoxy with a single piece of gauze, just like working with fiberglass and resin.
wormhole
7
Jan 2, 2011 08:36 PM
GhostriderTx
Dec 30, 2007 06:08 AM
atistang
Dec 12, 2006 04:04 PM
petros
Jul 29, 2006 09:27 PM
dirk diggler
21
Jan 3, 2004 08:25 AM
