'86 4x4 22R Ignition Module?
So ever since my truck died two weeks ago, I've been working through all the possible causes for it NOT getting any spark. I needed to change the plugs anyway, so I did that. I checked for spark but pulling a plug wire... nothing. So then I pulled the coil wire from the distributor... still no spark. Sooo... I figured the coil has died (it was the original one). Replaced that and still nothing. Checked the dist. cap and rotor, and they're in good shape.
Now I'm to the ignition module. Could this thing die? I checked all the wires running to it and they all seem to be sound, with no cuts, slices, corrosion at junctions. I've been looking around at new modules and they're friggin' expensive! Not really in the mood to spend between $330 and $450 for one, so is there any way to test mine to see if it has, in fact, bit the big one? If it has, does anyone know the best place to pick one up that's cheaper?
Thanks for the help!
Mister -- How much does he want for it? lol
Ignition modules rarely go bad, imho. Most likely another culprit.
At one point, the AFM killed my spark. Unplugging the AFM restored spark! (That was after I bought a used $70 module.)
Are you throwing any codes?
Codes? HAHA! The truck's an '86... no computers in there at all!
He would prolly ship it to you for less than $50. PM me. I'll give you his phone number.
sandyota
Feb 4, 2021 11:16 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
