'86 22RE-C Engine Wiring Harness Quandry
Old Dec 17, 2009 | 01:17 PM
NHEngineer's Avatar
I hope you Toyota rebuild veterans can help me out with this one. I started this rebuild project five years ago. Some delays, distractions and procrastination have taken their toll. I have the engine back together and in the truck. I have many of the wiring harness connectors where they belong but I'm mystified as the where the remaining [photo] five go.
The wires I'm stuck on are the ones that go between the upper and lower induction segments [if that's what they're called].
Just too much time has passed for me to recall where I took them from and my Chilton is about zero help. It's an '86 4WD Pickup with a 22REC motor. HELP!
Old Dec 17, 2009 | 03:21 PM
weaselman's Avatar
the yellow one is knock sensor. the white two are for the tranny. the clear one is for the starter. the one with the green wire is your 4wd light.
the blue one is the idle air control valve.
the ring is the ground that attatches up by the intake. (otherwise you cel will be on)
Old Dec 22, 2009 | 10:09 AM
NHEngineer's Avatar
Thank you Mr. Weaselman,
More questions:
1. Where is the mating knock sensor connector located [yellow, first on the left]?
2. The wire from the transmission only has the round connector. Is the oval connector not connected to anything [white, second from the left]?
3. Clear one OK. I got it.
4. Green wire [with connector]; where can I find the mating end?
5. Last one on the right [no connector]; Where is the air control valve located?
It's been too bloody cold in the garage this weekend so I've not been working on it. Now I got me a Salamander and CO detector so I back at it. Maybe I'll get it done to plow snow with soon, eh?
Old Dec 22, 2009 | 11:40 AM
weaselman's Avatar
1. Knock sensor is on pass side. Between the oil filter and fuel filter.
2. Yes the other plug is empty.
3. Good.
4. Should be on the pass side of trans. Near or around the white plug.
5. Idle air control valve is located under the intake plenum. But now that i look at that wire more. It might be for the engine coolant temp sensor (notorious for loosing connectors). Just a regular spade connector, which is on top of intake manifold.
Hope this helps. Lemme kno if you need more help.
Old Dec 22, 2009 | 12:21 PM
NHEngineer's Avatar
OK, I know what that one is.
OK, cool.
3. Good.
I'll get on the creeper and look for it once the garage is warmed up.
Weaselman, I already found the water temp wire. This one had a round connector on it that looked like the 4WD connector. I heard it drop to the floor but, as yet, I haven't been able to find it. It probably rolled under something.
Forgot to mention that I can't find the connector for the oil pressure gauge. None of the left overs match the connection on the sender.
Old Dec 23, 2009 | 06:16 PM
weaselman's Avatar
well then the one that is missing the connector could very well be the oil pressure gauge sender. ill see if i can find a picture of what it looks like for you...
Old Dec 23, 2009 | 06:38 PM
toyomoto's Avatar
the ol pressure sender is right below the oil filter. little solenoid with an electrical tab stickin out!
Old Jan 4, 2010 | 10:03 AM
NHEngineer's Avatar
Sorry for the delay in my response. I took the holidays off and now I'm hot to get that puppy running. Yes, please send a photo of the connector.
Old Jan 4, 2010 | 10:05 AM
NHEngineer's Avatar
Originally Posted by toyomoto
the ol pressure sender is right below the oil filter. little solenoid with an electrical tab sticking out!
Yup, I know where the sender is located. Thanks for your reply but it's the wire I can't find. Please read the thread and you'll have the full picture including pictures.
Old Jan 4, 2010 | 10:04 PM
weaselman's Avatar
i will do that tomorrow morning when the sun comes out. lol.
Old Jan 6, 2010 | 10:09 AM
NHEngineer's Avatar
I found the end that broke off the green wire. You were correct. It is for the oil pressure sender. Now all I need to do is finger out reattach it.
Old Dec 31, 2010 | 10:38 PM
Juanita's Avatar
white oval double clip....
I have a 1987 4runner, and I put my rebuilt 5 speed tranny in today. I have lost the mate to the white clip in your picture, as well as to the 2 clips on the tranny (reverse lights and 4wd dash light?) no one seems to know what the white clip does, and if it's important. The neutral safety switch has been mentioned a few times, but then negated because I have a 5 speed. Do you or does anyone know what the white clip goes to? Does it hook to both clips on the tranny? Thanks!!!
Old Jan 1, 2011 | 02:16 PM
weaselman's Avatar
are you talking abt the big white connector? if so. its for the reverse lights on the tranny. only one side of that plug is used. dont ask why toyota did that, they just did.
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
toyota32
Jul 6, 2015 05:42 PM
