86 22R Timing
Old Jul 1, 2019 | 01:19 PM
Brush Rat's Avatar
86 22R Timing
86 4x4 PU. 22R With crank at TDC and Cam gear properly aligned (Slot at 12 o'clock and dot at 11:59) If I turn the distributor all the way clock wise the best I can get is approx. 10 degrees BTDC. There is not enough slot to reach 5 degrees which is what this motor calls for. Any ideas??
Old Jul 2, 2019 | 10:22 AM
Brush Rat's Avatar
Found this today, will give this method a try tonight.
Old Jul 2, 2019 | 11:08 AM
snippits's Avatar
Follow the directions from 22RE Performance, and it will be stabbed right the first time.
Old Jul 2, 2019 | 07:56 PM
Brush Rat's Avatar
Worked like a charm. Thanks for the input Snippits.
77lubr
May 23, 2011 08:41 PM
hgill
Oct 28, 2008 05:57 AM
JD and Beastlet
Apr 18, 2008 07:30 AM
arielb1
Aug 11, 2007 11:27 AM
brendonv
Sep 20, 2005 06:18 AM
