86 22r Missing, Hesitating
Old Jul 26, 2010 | 12:15 PM
TCLade's Avatar
I have done the EGR test and the engine does stumble. I even blanked it off for a few days and there was still no change.
Someone mentioned the AAP in the carb might be broken. I checked the diaphragm and it's still good - no gas in vac lines. I also replaced the BVSV that controls the AAP, no change. Will try blanking off the vac line to the AAP but not too optimistic.
I am completely out of ideas!!! AAAARGH.
Old Jul 30, 2010 | 09:05 AM
TCLade's Avatar
Problem solved!!!!!!!
I put a 180* stat in by mistake - a 195* solved all the problems! Thanks guys.
Old Jul 30, 2010 | 09:10 AM
Lysmachia's Avatar
and how was it solved? Do tell...
Old Jul 30, 2010 | 11:01 AM
xxxtreme22r's Avatar
hmmm that's interesting. can someone explain to me how and why that worked? engine running colder so it isn't burning fuel as easily????
I just noticed why is there two identical threads posted from you about this?
Old Jul 30, 2010 | 11:02 AM
  #25
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
There's three. You missed one, it's a few threads down the list atm.
Old Jul 30, 2010 | 11:09 AM
  #26
na thats a similar issue but from someone different. I usually pick up on these things and let the mods know.
Old Jul 30, 2010 | 12:02 PM
  #27
TCLade's Avatar
Sorry about the multiple threads, I'm new to this forum business.
After scouring the net following a hunch on the stats, my theory on why this worked was that with a 180* the engine was running rich, maybe because the engine was not completely coming out of 'cold mode'. I'm not sure. It was a $10 hunch that sounded plausible and was backed up by a few posts on the net.
Either way it worked. I tried almost everything else!
Old Jul 30, 2010 | 12:06 PM
  #28
looking at the autozone websie, it's funny the 86 carb OE temp is 195 while the 87 carb is 180 hmmmm wonder why the difference.
Old Jul 30, 2010 | 12:07 PM
  #29
I got a 180 in mine with a 1/16" hole drilled into it because of a temp overshoot problem.
Old Jul 30, 2010 | 12:27 PM
  #30
TCLade's Avatar
Kragen sold me the original replacement which was 180* and at that point I didn't even think to ask. Another local independent store who I really respect, said 180* was 'regionally correct' for my car. I called Toyota and asked if I could buy a 195* from them and he didn't even hesitate when he said yes - $20 though.
PepBoys gave me the choice of 180* or 195*, so who knows.
All my hunting around the net, it seems to be a contentious topic with guys disagreeing. LCE even promotes the 180* as being the right one for 'perfomance'.
We'll see what happens this weekend, I'm heading to Tahoe and Nevada - HOT!
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
dumpster84
Apr 30, 2016 06:03 AM
Koolbananass
Aug 12, 2015 01:59 AM
TDonkey
Jul 26, 2015 10:14 AM
