850 mile trip in the runner, some issues came up
Old Nov 23, 2009 | 08:13 PM
  #81
camo31_10.50's Avatar
this thread has made my day....thank you all!!!lmfao
i wanna hear a 22r/re turning at over 5000 rpms..i never heard one over about 4500..LMAO
Old Nov 23, 2009 | 08:44 PM
  #82
Matt90V6SR5's Avatar
Camo...made your dad???
Old Nov 23, 2009 | 08:46 PM
  #83
Junkers88's Avatar
Originally Posted by camo31"10.50"
this thread has made my dad....thank you all!!!lmfao
edited.
Old Nov 23, 2009 | 08:48 PM
  #84
BigBluePile's Avatar
Why has he got to be little? Geez that's a mean thing to say.
Anywho, what about oil?
Old Nov 23, 2009 | 08:51 PM
  #85
I run my V6 at 3k RPM (70mph) and my oil guage stays at the halfway mark,so I guess Im doing good then.I wont even attempt to run it at the RPMS you guys are talking about.
Old Nov 23, 2009 | 09:01 PM
  #86
fixed it..lmao..
Old Nov 23, 2009 | 09:24 PM
  #87
Camo,LMAO at that made your dad comment.Was gonna ask you: made your dad do what,lol.
Old Nov 24, 2009 | 05:55 AM
  #88
Junkers88's Avatar
Originally Posted by Gnarly4X
Yes, Junkers, that's right. I think T was thinking something else. Teuf, what ARE you saying?
gNARLS.
Yes! Finally got one right!!
Old Nov 24, 2009 | 08:57 AM
  #89
shaeff's Avatar
that could be true..but i've drove my truck at about 3500rpms for a while..(bout..maybe 100miles)..with some downshifting to around 4200 rpms..screamin up some big hills lol..and my pressure on my mechanical gauge was still reading about 50-60psi
im just runnin 10w30..but i usually run some 20w50.. it cuts down on leaks..runs higher pressure..and should help with bearings...of course i could help bearings even more by throwin some synthetic Royal purple in it......
Just keep in mind that pressure is resistance to flow. Just because you have high oil pressure does NOT mean that the heavier oil is lubricating the motor better than a 5w-30. And that 20w50 takes longer to circulate through the motor when cold-started. Cold start is where most engine wear occurs. Just some food for thought.
I've been running synthetic 5w30 in the truck since I got it with 100k on it. It's now got 160+k, no issues at all.
Old Nov 24, 2009 | 09:08 AM
  #90
Teuf's Avatar
I was jesting, ( whats 4500 rpm and 90 miles per hour ). GOOD POINT SHAEFF, thats what i am Going too, 5/30 syn blend.
Old Nov 24, 2009 | 09:09 AM
  #91
Teuf's Avatar
(to)
Old Nov 24, 2009 | 09:25 AM
  #92
TOYOTA 1's Avatar
i thought 6,250rpm rev limiter is a shift light/ motor saver all in one?
Old Nov 24, 2009 | 09:43 AM
  #93
Junkers88's Avatar
Unless you've got a really high mileage old tired engine, I wouldn't run 20-50 in a 22.
Just food for thought.
gNARLS.
Not to get into a deeper discussion than this already is but at what point do you consider a 22 to be high milage? I switched from 10w30 syn to the 20w50 because of a little rod slap (that's what it sounded like any way) at start up. It only did it when cold and there was only one or two smack noises. With the 20-50 the noise is gone.
Old Nov 24, 2009 | 09:52 AM
  #94
TOYOTA 1's Avatar
no way.. when you run them harder they build up a tolerance!
im jk, and yea i know that the harder you run it the harder it will break
the valves dont float untill about 7500rpm.
Old Nov 24, 2009 | 10:10 AM
  #95
Hey man, my aftermarket electrical gauges work great!!
Old Nov 24, 2009 | 10:26 AM
  #96
TOYOTA 1's Avatar
Dude, I think you're smok'n some bad crack!! A stock 22RE won't even turn 7,500 under power, you *might* get one to that RPM on a missed shift or sitting in the driveway stomp'n the throttle to floor, but I'd have to see it happen.
The valves will start floating about 5,600. A stock cam in a 22RE will not flow enough to get to 7,500 grand!!
As I said before, I've hit 6K on my tach in the dunes with my stock 22RE with a DT header, but I only did it a few times and the power had dropped off at 5,000 RPMs.
Luckily, the stock 22RE is a non-interference engine and even if you float some valves they probably won't smack a piston.
If I'm wrong here, enlighten me... I'm all ears!!
gNARLS
i dont think you know what your talking about, a atock 22re will turn 6,250rpm that is the rev limiter and it will turn it just fine with no valve float.
as for the 7000rpm i said 22r witch doesnt have a rev limiter besides valve float. and the motor wasnt stock, i said it had no internal mods besides a cam. they will turn 7k!
do you even have a tach? lol jk
Old Nov 24, 2009 | 10:38 AM
  #97
Junkers88's Avatar
Good question Junkers.
Well, you probably heard PISTON slap, not rod slap at cold starts. Bad or worn rod bearings usually cause a "knock".
I think when a 22 starts to use (burn) a quart of oil every 2500 miles, you've got a tired engine. At that point, running 20-50 probably ain't gunna hurt it. And, if you've got some loose parts (piston slap, loose mains, rods, etc, running a thicker oil will definitely quiet it down.
TJMWO,
gNARLS.
Oh. Well now it seems I can't even diagnose what the damn noises are in my rig. Thanks for the info.
So far my truck doesn't burn any oil, it does leak a little but that's because I was stupid and didn't change the rear main when I did the clutch...
Old Nov 24, 2009 | 10:46 AM
  #98
a non interference motor? Since when?
Old Nov 24, 2009 | 12:13 PM
  #99
damn I thought I had you there.
Old Nov 24, 2009 | 03:31 PM
  #100
TOYOTA 1's Avatar
You know this RPM topic has come up many times, and there is always some magic engine out there that turns up magic RPMs "all day long".... but, I know two very experienced Toyota engine builders that build professional race engines that win races "all day long", and get paid big bucks for them. Both said the same thing... on a stock 22RE, the valves will float at around 5,600 RPM. Now if you know more than they do, great. But, I'm going to put my money on those two experts!!
well you can believe what you want, but the valves wont float at 5600 thats just plain silly. if they do, your motor may have some problems.
OK, whatever you think.
Where did I say that a stock 22RE won't turn 6250?
when the valves start floating the motors rpms stop climbing, essentially becoming a rev limiter. so when you say that the valves float at 5600 that would be your max rpm.
oh and if the valves floated at 5600 (which they don't) why would toyota put the rev limiter at 6250?
A modified 22R may turn 7,000 RPM, but it would have to be heavily modified to stay together long.
i never said it would last long.
Having a rev limiter at 6,250 on a stock 22RE does NOT mean the valves won't start floating at 5,600 RPM!!
unless there is something wrong with your motor, yes it does.
And I still think you are misleading the facts!! And... your butt is STILL sucking sewer water!!
im not misleading anything, and you sound like a child.
Note: Judging from your avatar photo, you also may have been suck'n some bad MUD!!
actually it was good mud you should get out and wheel sometime, its fun!
Now see, if your valves were "floating", then you may not have sunk your truck!!
gNARLs.
hahaha i like that one. yea after that i stay away from those big ones
