84 pickup rebuild Oil smells of gasoline!!!
Old Nov 9, 2009 | 02:41 PM
luddite20's Avatar
Exclamation 84 pickup rebuild Oil smells of gasoline!!!
my yotatech amigos. I finished the rebuild, got er running, got er to pass smog, but am pretty sure the oil is getting contaminated by gas. I replaced the oil right before my smog test, and this time I passed, though I also adjusted the valves again (more accurately) and replaced the threads in my number 4 spark plug hole, which was loose. I replaced the rings in my rebuild, so I'm surprised I'm getting this much gas in my oil. It had been running rich, and maybe still is (I was getting high CO in my emissions test). What could be causing this? How can I tell? You guys rock!d
Old Nov 9, 2009 | 03:00 PM
luddite20's Avatar
Help!
Old Nov 9, 2009 | 03:10 PM
austinmacry's Avatar
i havent had this problem yet on my 4runner but on the vehicle before her godliness i had a 02 mitsi lancer. Had the same issue where gas and oil were mixing. I replaced the valve cover gasket and had no more issues?
Old Nov 9, 2009 | 03:14 PM
luddite20's Avatar
interesting. but I don't see how the valve cover gasket would come into play. Isn't the valve cover gasket only keeping the oil in the camshaft? Tell me why this worked for you.
Old Nov 9, 2009 | 04:19 PM
75k5toy's Avatar
Long time ago, I had a similar problema, caused by a busted "mechanical" fuel pump. salud amigo.
Old Nov 9, 2009 | 04:27 PM
Sorry sorry sorry, Delete that post, I was thinking of oil in the spark plug area.
GreenLion
Jun 7, 2021 10:49 AM
85run
Jul 8, 2015 11:20 PM
puddlepirate
Jun 30, 2015 05:08 PM
WI Girl
Jun 25, 2015 03:45 AM
Mack
Sep 1, 2002 03:19 PM
