4x4 vibration and pull
Old Oct 13, 2010 | 02:22 PM
ser91's Avatar
i noticed a pretty decent vibration while in 4x4 from the front end and the truck seems to pull to the right... it also sounds like i light clanking sound from the passenger front hub too... it's a light noise, kinda like a cotter pin loose but with a little more weight... at the same time this started, it had a hard time coming out of four wheel drive, it took almost a 1/4 mile then finally on a hard turn it popped out, but not violently or anything... when it is out of four wheel drive, it is perfect... i looked underneath and the driveshaft and u-joints apper to be ok...
i'm mostly asking this because i am kind of new to these trucks and was wondering if there was a common problem or what the likely part could be before i buy a new everything... please let me know if there is something that is likely to be causing this or if you've had the same issue! thanks
-Sam
btw, it's a 94 pickup V6 4x4 manual 5 speed... extended cab long bed if that matters...
Old Oct 13, 2010 | 03:12 PM
Outsane's Avatar
do you have manual locking hubs?
Mine will vibrate near highway speeds if I leave my hubs locked
Old Oct 13, 2010 | 03:19 PM
ser91's Avatar
yes i do... i was thinking it was something it the hubs as well, but i'm just not sure if there was something more common that goes bad on these... but that's one possibility along with many others... lol
Old Oct 13, 2010 | 03:20 PM
ser91's Avatar
and also, it was vibrating at even 15-20mph
Old Oct 13, 2010 | 04:26 PM
Outsane's Avatar
Double check that the hubs are unlocked
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
garagespace
Jul 9, 2015 08:37 AM
