4WD light stays on??
Old Feb 20, 2013 | 06:30 AM
mldave's Avatar
Snowed hard yesterday,then melted and light ice on the roads.Put it in four wheel drive to get home from the coffee shop for better traction and never went more than 15 mph,some of the pavement was dry in the three block drive.When I parked and shifted back to 2 Hi the light stays on for 4WD.What happened?
Old Feb 20, 2013 | 06:39 AM
StewsRunner's Avatar
Put it in reverse and drive backwards for maybe 100 ft. If it stays on try getting your tires to spin on an icy patch to make sure you are actually in 2H. Just slightly step on the pedal. .
Old Feb 20, 2013 | 06:56 AM
mldave's Avatar
Steven,all the ice is gone now.
Old Feb 20, 2013 | 06:57 AM
Then find some gravel
Old Feb 20, 2013 | 07:02 AM
mldave's Avatar
Will it hurt anything to drive in 2Hi with the 4wd light on and hubs unlocked?
Old Feb 20, 2013 | 07:04 AM
I don't think so, you failed to mention that first, but i forgot to ask. Even if you shift into 4H and DO NOT lock the hubs, you're still in 2H. I do not think it'll harm anything TCase related.
Old Feb 20, 2013 | 09:10 AM
MudHippy's Avatar
You don't have to be on a low traction surface. Just reverse, forward, reverse(as many times as necessary), while trying to shift the transfer case into 2H(since you aren't in 2H...until you hear/feel it shift out of 4H...and the 4WD light goes off). Having the hubs locked, or unlocked, while you're doing it doesn't matter.
Old Feb 20, 2013 | 11:32 AM
Greg_Canada's Avatar
I find it helps more turning left and right, and putting it into neutral while doing this, when trying to get out of 4x4. Back and forth never does much for me.
fountain
Dec 31, 2015 06:08 AM
adammtb
Jul 27, 2015 11:57 AM
nonstop
Jul 24, 2015 06:29 PM
mluz013
Jul 24, 2015 12:31 PM
Odin
Jul 15, 2015 09:28 PM
