4Runner 94' Weak Transmission?
Old Jan 21, 2012 | 10:32 AM
4Toyota's Avatar
I recorded it, please have a look.
www.youtube.com/watch?v=eHa4gWHE1SY
Old Jan 21, 2012 | 11:44 AM
McKenna's Avatar
But does it still rev that high when you cycle through your gears manually (Not in Drive) ? If not then it would be a shift solenoid.
Old Jan 22, 2012 | 03:20 AM
4Toyota's Avatar
All the gears work except for "D"
I'm scrapping the 4Runner anyways at a lost. :/
Old Apr 19, 2015 | 01:54 PM
Manuel Taylor's Avatar
I am having a similar problem. I have a 94 4runner. My problem started after I had replaced the radiator. As of now i have a leak in one of my transmission cooler lines ( in the process of replacing it). The truck shifted fine after it warmed up(not an issue).Now the truck will need to be red lined to move slightly. then it will shift fine afterwards. I have replaced the fluid and the filter(no metal shavings) also I have replaced all of the solenoids. I do have the same problem in 4LO. reverse works great. Any help with this issue will be greatly appreciated.
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
shar
Jul 9, 2015 12:38 PM
madxman21
Jul 9, 2015 10:26 AM
