4lo won't stay locked in position??
Old May 29, 2017 | 07:09 PM
this_marine's Avatar
Hey Guys,
I cant figure out why my 4runner won't stay locked in 4lo...my lever won't even push it far enough to lock it into 4lo , I can go underneath and push it and it will engage,then once I hit a bump it throws it self out of 4lo and into 4h...its weird all the bushing look good on the linkages and no play...is it possibly just the shift lever?? What do you guys think? Thanks
Old May 29, 2017 | 07:15 PM
Co_94_PU's Avatar
Could be bent linkages. Disconnect it, put the lever locked to position and adjust.
Old May 29, 2017 | 07:25 PM
millball's Avatar
What model, year, engine and tranny machine you got??
Old May 29, 2017 | 08:00 PM
Ok Thanks I'll try that...Its a 91, 3.0, A/T a340
Old May 29, 2017 | 09:31 PM
thook's Avatar
mine did the same thing after i'd had a wreck. this was years ago. the t/c linkage...whatever that C shaped thing is called/can't remember.... on the t case was bent.
